Policy routing and dhcp
I have a router performing dhcp server and policy based routing on the same interface. Incoming dhcp requests are being policy based routed. Can this funtion be disabled/bypassed?
1 REPLY
Anonymous
N/A
Re: Policy routing and dhcp
You are probably using a route-map with no "match" command. You must use a match command and create an exception for the DHCP packets in the match criteria you are applying to the route-map.Try creating an extended access-list where in the first line you deny DHCP packets, and in the second line you permit everything. Then configure a match command in your route-map making reference to that access-list. Something like this:
access-list 101 deny udp any any eq 67 (I think this is DHCP...)
access-list 101 permit ip any any
route-map permit 10
match ip address 101
set interface
Hope this works :))
Paulo
128
