Poor packet throuput on virtual-access interface versus dialer interface
I am using a 2503 to test per-user aaa dialin. The modem is attached to the AUX port, which is set to be an async line. When I dial in using a user with per-user aaa settings, any routed packet incurs very long delays (pings take 1-10s to get responses). If it simultaneously ping the NAS, the response times drop to a more respectable avg 500ms. The same laptop dialled in using a non per-user aaa user gets 150ms ping responses to the NAS and any routed destination (along with expected small addition delays caused by routed links in the path).
Is this a factor of the under-spec’d 2500? Or is this something I have created in the configuration? Sanitised config below:
version 11.3
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname APH_DIALGATE
aaa new-model
aaa authentication login standard tacacs+
aaa authentication login nwadmin tacacs+ local
aaa authentication ppp standard if-needed tacacs+
aaa authorization exec standard tacacs+
aaa authorization exec nwadmin tacacs+ local
aaa authorization network mustusetacacs tacacs+
aaa authorization network standard if-authenticated tacacs+
aaa accounting exec default start-stop tacacs+
aaa accounting network default start-stop tacacs+
enable secret *************************************
username *********** privilege 15 password ********************************
no ip domain-lookup
virtual-profile virtual-template 1
virtual-profile aaa
async-bootp dns-server 10.3.185.16 10.4.185.16
async-bootp nbns-server 10.4.185.16 10.3.185.16
isdn switch-type basic-net3
clock timezone AEST 10
clock summer-time AESuT recurring last Sun Oct 2:00 last Sun Mar 2:00
interface Ethernet0
ip address 172.29.1.14 255.255.0.0
no cdp enable
interface Virtual-Template1
ip unnumbered Ethernet0
peer default ip address pool default
ppp authorization mustusetacacs
interface Serial0
ip address 172.25.1.2 255.255.255.0
interface Serial1
no ip address
shutdown
interface BRI0
no ip address
encapsulation ppp
no logging event link-status
dialer rotary-group 0
autodetect encapsulation ppp v120
isdn incoming-voice modem
no cdp enable
interface Async1
encapsulation ppp
dialer in-band
dialer idle-timeout 86400
async mode interactive
no cdp enable
ppp authentication chap standard
ppp authorization standard
interface Dialer0
encapsulation ppp
dialer in-band
no cdp enable
ppp multilink
ip local pool default 172.29.2.1 172.29.2.60
ip local pool GAUSER 172.29.3.1 172.29.3.60
ip classless
ip route 0.0.0.0 0.0.0.0 172.29.1.1
ip route x.x.x.x 255.255.255.255 172.25.1.1
ip access-list extended GAUSERfilter
permit ip 172.29.3.0 0.0.0.255 host x.x.x.x
deny ip any any
logging console warnings
dialer-list 1 protocol ip permit
tacacs-server host 10.3.185.17 single-connection
tacacs-server timeout 30
tacacs-server key *****************
snmp-server community ******** RO
snmp-server location ***********
snmp-server contact ***************************
line con 0
exec-timeout 0 0
login authentication nwadmin
line aux 0
session-timeout 60
timeout login response 60
autoselect ppp
session-disconnect-warning 600
login authentication standard
modem Dialin
modem autoconfigure discovery
transport input all
speed 38400
flowcontrol hardware
line vty 0 4
exec-timeout 0 0
transport input telnet
ntp clock-period 17179761
ntp server 10.1.0.5
scheduler interval 1000
end
1 REPLY
Re: Poor packet throuput on virtual-access interface versus dial
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
95
