Community Member
poor performance on C3550 when doing InterVLAN routing and HSRP
I encounter very poor performance when doing InterVLAN Routing on a C3550 between VLAN1 and VLAN2 . Both VLANs are HRSP´d
See the config i have attached. When doing ftp from a PC directly connected to G0/11 to a server connected to G0/12 i get not more than 1100 KByte/s. Doing this in the same VLAN brings up to 5000 KByte/s. Is this normal or do i wrong ?
version 12.1
no service pad
service timestamps debug datetime
service timestamps log uptime
service password-encryption
hostname sw-ghrz-1-c3550
logging file flash:/syslog 32768 1024 debugging
enable secret secret
clock timezone MEZ 1
clock summer-time MESZ recurring last Sun Mar 2:00 last Sun Oct 2:00
ip subnet-zero
ip routing
ip domain-name mydomain.net
ip name-server 10.100.10.1
ip name-server 10.100.11.1
vtp file flash:/my_vtp
udld aggressive
spanning-tree vlan 1 hello-time 1
spanning-tree vlan 1 forward-time 4
spanning-tree vlan 1 max-age 6
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
switchport access vlan 1
no ip address
interface GigabitEthernet0/12
switchport access vlan 2
no ip address
interface Vlan1
ip address 10.100.2.11 255.255.0.0
no ip redirects
ip route-cache flow
no ip mroute-cache
standby ip 10.100.1.6
standby timers 10 20
standby priority 200
standby preempt delay 30 sync 10
standby authentication rtgrvl1
standby name rt-vl1
interface Vlan2
ip address 46.109.60.2 255.255.252.0
no ip redirects
ip route-cache flow
standby ip 46.109.60.1
standby authentication rtgrvl2
standby name rt-vl2
ip default-gateway 10.100.1.1
ip classless
ip http server
logging trap warnings
logging source-interface Vlan1
logging 10.100.10.14
cdp timer 30
snmp-server engineID local 800000090300000A8A706301
snmp-server community xxxyyyzzz RW
tftp-server flash:/syslog alias syslog
banner login
Welcome to sw-ghrz-1-c3550
line con 0
line vty 0 4
password secret
login
line vty 5 15
login
ntp clock-period 17180226
ntp server 10.100.10.14
end
Re: poor performance on C3550 when doing InterVLAN routing and H
What software version are you running? Try with the latest 12.1(9)EA1 and see if you still have the same issue
Community Member
This version is running. Is anything wrong in configuring two VLAN Interfaces for routing ? Should it be done via IRB ? Any help welcome.
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(9)EA1c, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 28-May-02 10:31 by antonino
Image text-base: 0x00003000, data-base: 0x00685778
ROM: Bootstrap program is C3550 boot loader
sw-ghrz-1-c3550 uptime is 4 weeks, 22 hours, 16 minutes
System restarted at 20:20:59 MESZ Thu Aug 22 2002
System image file is "flash:c3550-i5q3l2-mz.121-9.EA1c/c3550-i5q3l2-mz.121-9.EA1c.bin"
cisco WS-C3550-12G (PowerPC) processor (revision B0) with 65526K/8192K bytes of memory.
Processor board ID CAT0630Z12E
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
149
