Port aggregation between Netscreen and Cisco
Does anybody have experience/tried to configure port aggregation between a Netscreen ISG2000 and a Cisco Cat 4003 ?
If yes pls provide me some info since all the tests I did doesn’t worked out…
I tried to config ether-channel on Cisco and aggregation interface on Netscreen with no success.
Netscreen says it currently works but no tech explaination I was able to find out on the web.
Tks
Ric
  • Other Network Infrastructure Subjects
Re: Port aggregation between Netscreen and Cisco
you will have to use LACP (PAGP is Cisco proprietary). So the Cisco config could look like this:
interface GigabitEthernet0/0
switchport mode trunk
channel-group 1 mode on
interface GigabitEthernet0/1
interface Port-channel1
Hope this helps
Martin
4003 supports only Sup1 and hence runs CAT OS only. LCAP is supported in CAT OS from 7.1(1) and later. The following page should help you with configurations
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/rel7_6/config/channel.htm#1048854
The commands are gonna be like
set channelprotocol lacp
Note that this will change channel mode on the entire module. Then you can assign the ports to the channel using the following example(port 3/33-34)
set port lacp-channel 3/33-34 mode active
Martin, in your config what does it specify to use LACP?
The config posted by martin doesnt include any etherchannel protocol related config.
its uses the option on which will bring the port to channel unconditionally and with that option selected u wont be able to mention out the protocol selection.
u can make use of channel-protocol LACP/PAGP to select the protocol and channel-group number mode {active | auto | desirable | on | passive} to select the different modes supported by different protocols.
regds
1364
