Webcast-Catalyst9k
port channel as a layer 3 interface
I have just inherited a very complex network and noticed in the config, for a cat-6513 with layer 3, the following:
interface Port-channel34
ip address 10.20.4.10 255.255.255.252
What would be a rationale for making a port-channel a layer 3 port?
thanks.
Re: port channel as a layer 3 interface
Have you ever configured a multilink ppp interface?
Vlad
Blue
in the case of a portChannel as an L3 entity, it allows for the added capacity/redundancy of the link as well as provides the layer 3 topology either wanted or in some instances, required, such as when you need to make a multilink connection to a router from your switch.
or perhaps you have a routed core infrastructure created in your L3 environment and you wish to increase the capacity of the links between devices without using VTP/trunking.
Thanks for your response. Would it be possible to point me to a doc discussing this feature? Thanks again
Hi greg,
See the following link for configuration of layer 3 etherchannels
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e6d3.html#wp1020478
Narayan
147
