Webcast-Catalyst9k
Port channel issues
The port channel ports are getting into disabled mode
Re: Port channel issues
Do the ports within the group have similar configs?
Thanks.
Hi Iqbal,
I think your port channel is going into errdisable state. Are you also running PAGP or the port channel is been cofigured in on mode?
Make sure the config like speed, duplex should be same in on mode and also make sure the channel group number should be same on same switch between the ports who you want to be in a port channel.
In short the port channel config should match between the 2 switch.
HTH, if yes please rate the post.
Ankur
126
