port-channel question for RSM int G3 & G4
Hello all, I'm sure someone can help me out with this one....... I have two 4006's and each have RSM's in SLOT 2. I'm seeing some route flapping between my port-channel from the SUP II's point of view. I have those 2/1-2 port-channelled and trunked. Can someone review the output that I have provided and let me know what's going on????
CORE-A> (enable) show channel group 2
Admin Port Status Channel Channel
group Mode id
2 2/1 connected on 801
2 2/2 connected on 801
Admin Port Device-ID Port-ID Platform
group
2 2/1 Not directly connected to switch
2 2/2 L3-RSM-A GigabitEthernet4 cisco Cat4232L3
Here is the CORE-B switch output..............( it's almost the same but look @ 2/2, it's opposite from CORE-A's output ?????????)
CORE-B> (enable) show channel group 2
group Mode id
group
2 2/1 L3-RSM-B GigabitEthernet3 cisco Cat4232L3
2 2/2 Not directly connected to switch
Here are the "show trunk command outputs"...............
CORE-A> (enable) show trunk 2/1
* - indicates vtp domain mismatch
Port Mode Encapsulation Status Native vlan
2/1 nonegotiate dot1q trunking 1
CORE-A> (enable) show trunk 2/2
2/2 nonegotiate dot1q trunking 1
Here is CORE-B's output for the trunk mode..............
CORE-B> (enable) show trunk 2/1
CORE-B> (enable) show trunk 2/2
*NOTICE* I have boths module 2/1-2 trunking modes in NONEGOTIATE due to those backplane channels connecting to the RSM's, I wanted to force that trunk and not generate any DTP frames. Can someone help me out ??
Thanks in Advance,
Alonzo
  • Other Network Infrastructure Subjects
Re: port-channel question for RSM int G3 & G4
I looks like it is setup well. But, I don't see the whole config. Make sure you follow this link step-by-step.
http://www.cisco.com/warp/public/473/28.html#Sample config
You will not have a problem. I have given it out to thousands of customers.
The port channel showing up as "Not directly connected to switch" is a known cosmetic bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdp04017
This is a known IOS s/w bug. When channeling in ON mode, the ports show the neighbor info using CDP data. The IOS s/w sends out CDP packets on both channel interface and physical interfaces. One of the cat ports sees multiple CDP neighbors and reports "not directly connected to switch."
You might also want to look at a previous posting for similar question
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26mode%3Dnew%26location%3D.ee84ef3
Thank you for your help. I don't like the way it looks but is from what your saying it should NOT impact performance right?
~Alonzo
219
