Port-Channel Question (simple question)
Hello all, I was just wondering about the Port-Channel command on the 4006. I have an RSM in slot 2 of my 4006 but I was wondering about where you type int the Port-Channel command. Is it on the router interfaces or can you configure the Layer 2 Switch ports as well?
1 REPLY
Re: Port-Channel Question (simple question)
Both. You need to channel both on Supervisor and RSM. You can find more info and sample config on CCO at
http://www.cisco.com/warp/public/473/28.html
If you need access-lists, you cannot use the channel option but you can use the gig interfaces independenty
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/78_10164.htm#xtocid68
92
