Port Channel using one port
is it possible to create a port channel using only one gbic port.
Please advice
Mahmood
Re: Port Channel using one port
Hi Mahmood,
Yes it is possible. But then WHY do you want to create a port channel if you want only one port to be a part of it?
It is as good as a nomral port with no load sharing and no redundancy.
HTH, if yes please rate the post.
Ankur
HI
Thanks ankur actually i was going through some configs at a site there i saw this but as u have said i am also not able to figure out why they have created a port channel using one port.
any ideas
Mahmood
Hi Mahmood,
Only option I can think of is that they might have configured some other port also in that port channel but might be that port is down or that card (modular switch) is out of the chassis.
Or might be thay have a future plan to configure more ports in that port channel.
Ankur
Hi Mahmood,
Ankur
Hi Ankur
But the port is on supervisor engine actally it is a cat6513.
Mahmood
113
