You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Port Flow Control 6509
Can someone tell me the difference between using flow control Desired on vs Desired OFF.
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: Port Flow Control 6509
These are the flow negotiations between the trunk links between switch #on indicates the local port sends flow control to the far end; #off indicates the local port does not send flow control to the far end; #desired indicates the local end sends flow control to the far end if the far end supports it.
229
