Port LED Flashes on Large file transfer
I have a 2950T switch with IOS 12.1(22)ea8a. I have a server connected to the G0/1 port and a workstation connected to any of the Fast Ethernet ports. When i do a large file transfer (workstation image, or and ISO file) the GIG port where the server is connected flashes from green to orange. Is there something wrong with the switch?
Dan.
Silver
Re: Port LED Flashes on Large file transfer
Please check the LED section in below link that describe the flash amber meaning.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_installation_guide_chapter09186a008007eadc.html
Please describe the amber is in STAT or UTIL mode ?
Moreover, please also check the port status when there is color change.
Hope this helps.
Silver
Aside from the advice of Jack, check your interface statistics. Are you seeing CRC, output and/or inpute errors by any chance?
show interface Gi0/1
--Leon
* Please rate all posts.
Yes there are input and crc errors. Could this be a driver problem on the server?
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 000c.5866.4619 (bia 000c.5866.4619)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is RJ45
input flow-control is off, output flow-control is off
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 14000 bits/sec, 16 packets/sec
5 minute output rate 17000 bits/sec, 18 packets/sec
2298420 packets input, 1948227851 bytes, 0 no buffer
Received 378 broadcasts (0 multicast)
453 input errors, 453 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 8 multicast, 0 pause input
1613489 packets output, 210713280 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Dan.
Hall of Fame Super Bronze
I see you hardcoded the speed/duplex at the switch side. Did you manually set the speed to 1GB/FD at the server as well ?
You can also try auto/auto at both ends and see if the errors go away.
Silver
In additional of the comment from Edison. Please also try to check the UTP cable can support 1Gbps or not. Is it Cat5e or CAt6 cable ?
I think it is more on the cable or the server side problem.
Hope this helps.
The speed and duplex are both at auto. I did not hardcode them. I have changed the cable many times already with no sucess. The server shows its connected at 1000, full. I even went as far as putting a different server on that port. No sucess with that either.
Can we see the switch config ?
Building configuration...
Current configuration : 4002 bytes
! Last configuration change at 14:03:17 UTC Fri Sep 1 2006 by admin
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname tech2950
clock timezone UTC -6
clock summer-time UTC recurring
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast trunk
interface FastEthernet0/2
switchport access vlan 500
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 160
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 200
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
switchport access vlan 25
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport mode trunk
interface Vlan1
ip address 192.168.0.12 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.5
ip http server
snmp-server community public RO
snmp-server community private RW
snmp-server location altona
snmp-server contact admin
line con 0
exec-timeout 0 0
line vty 0 4
exec-timeout 0 0
login local
line vty 5 15
exec-timeout 0 0
login local
ntp clock-period 17179892
ntp server 192.168.50.1 key 0 prefer
end
Can you swap G0/1 with G0/2 ?
Can you set the speed/duplex manually at both ends ? It could be a problem with autonegotiation.
Silver
It is just a reminder that if swap two G0/1 & 0/2, pls. remember to swap the config. too.
Can you also clear the counter of the GE interface to determine how fast of the error growth ?
124
