Port lock down
Is it possible to lock a port on a Switch down so the host can only access the Network when connected to that Post. I am trying to prevent Users from moving their PCs around, I would like to Map the MAC addresses to specific ports on the Switches.. Thanks.
Re: Port lock down
Yes..You can use the Port Security feature. What switch do you have. Go the configuration guidelines and you'll find the commands you need
http://www.cisco.com/univercd/cc/td/doc/product/lan/index.htm
Re: Port lock down
Thanks very much.
104
