Community Member
PORT MONITOR over a switch 2900XL adnd 3500XL
I would like to know it's possible to modify the parameters " transmit or receive " with the command " port monitor " with the switchs 2900XL and 3500XL running version 12.0.(5)WC5 ?
I know that is possible with a switch in CatOS with the command " port span ".
Thanks in advance
1 REPLY
Re: PORT MONITOR over a switch 2900XL adnd 3500XL
No, it is a low end switch with a certain price point.
http://cco/univercd/cc/td/doc/product/lan/c2900xl/29_35wc5/cli/clicmds.htm#xtocid55
You will have to do it on the sniffer.
Here is a free sniffer we alway use in the shop. And yes , it works on windows.
www.ethereal.com
112
