port monitoring on 2948GL3
Greetings!
Would anyone know how I might configure an interface on the 2948 so I might capture traffic with a protocol analyzer? I was told I could span ports but I cannot find a way to do this. I tried using RMON but I think I need an SNMP agent to use this feature.
Any suggestions are appreciated,
SG
Re: port monitoring on 2948GL3
A 2948G-L3, which is an IOS switch, has only routed ports and does not have the ability to perform Layer 2 switching and can therefore not SPAN ports.
A 2948G, which is a CatOS switch, is a layer 2 switch and it does have SPAN functionality. To configure a port on a 2948G as a SPAN port to connect to an analyzer, check the following link:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_5_5/sw_cfg/span.htm
L3 switch does not support SPAN. I have had customers connect a hub inbetweeen and capture sniffer traces when i had to.
Thank you both for your solutions. I appreciate it.
94
