bma
port problem with ISDN
I have ISDN line on the cisco 3640 route. Telnet and
Ftp are fine on the ISDN line, but get time out when
running SQL application with port 1433. It's fine
to run same application on the same route with Frame relay. Please help!
Ben
Re: port problem with ISDN
are both b channels coming up?
compare the round trip time between the frame and the ISDN On 2 working applications.
Any access lists ?
bma
How to know both b channels coming up?
I bulit other isdn route on the my location, it's no problem to run Sql application with port 1433 to the same route. Problem is on the U.K. office ISDN route. do you think it has difference from international call with U.S.A. local isdn call?
On the routes, we don't have any limit for port 1433.
ben
try the show isdn active ...
is it 56 or 64 b channels ?
112
