Webcast-Catalyst9k
Port Security on LAN Switches
What is the equivalent IOS switch command for the Catalyst 6509 CAT OS <set port security> command.
on other IOS switches like the 3550 series there is a command - switchport port-security. i need to know the command on CAT6509
1 ACCEPTED SOLUTION
Re: Port Security on LAN Switches
Release 12.1(13)E and later releases support the port security feature.
eg.
Router(config-if)# switchport mode access
Router(config-if)# switchport port-security
Router(config-if)# switchport port-security maximum 1
Router(config-if)# switchport port-security mac-address xxxx.xxxx.xxxx
Router(config-if)# switchport port-security violation shutdown
See link: http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a00800da706.html
Hope it helps.
Steve
1 REPLY
eg.
Hope it helps.
Steve
108
