07-23-2003 09:47 AM - edited 03-02-2019 09:04 AM
Can one use port security (limit the learned MACs)on a Cat 3500/3550/4000 to stop users from connecting a wireless access point?
If yes, will the first client on the access point be blocked? What is the command syntax?
Ted
07-23-2003 06:18 PM
Port security can be used to stop users from connecting pretty much anything. You explicitly permit source MAC addresses that are permitted on a given port and any others are denied.
The syntax varies greatly depending on switch model and OS version. See the documentation: http://www.cisco.com/en/US/products/hw/switches/index.html
07-30-2003 12:32 AM
Using Port Security you can also limit the number of MACs learned on each port, i.e. set the value low to prevent connection of a hub/switch to a users host port.
07-24-2003 05:36 PM
This depends on if the access point in question has a mac address that is entered in the cam table. If it does, then obviously the first client will end up causing the port to be disabled. If it doesn't then the second client will (assuming that you are configured for only a single mac address).
Keep in mind that by enabling port security you are potentially increasing the amount of administration you have to do. You can also look at using bpduguard to accomplish this same thing since this will shut down a port in portfast mode if a bpdu is received on it.
07-30-2003 07:57 AM
We typically disable portfast on the 10/100 ports that our access points connect to. Doesn't portfast need to be enabled in order for bpdu-guard to work?
