Port state = Down Not-in-Bndl
Could anyone tell me how to get one of my interfaces back into it's etherchannel? This is the message I get regarding the interface.
When I do a show ip int brief I get the "down - down"
As you can see the ports are configured the same, with the exception of the protocol part... it won't let me remove it.. 1/1 is up and operational..
interface GigabitEthernet1/1
switchport trunk allowed vlan 1,20
switchport mode trunk
channel-group 40 mode desirable
interface GigabitEthernet1/2
channel-protocol pagp
Re: Port state = Down Not-in-Bndl
First, please verity that port 1/2 is connected to a properly configured etherchannel on the
other side. If possible, please physically trace the cables and verify that they are in the proper
corresponding ports on the other side. Sometimes this is caused due to mis-cabling of ports.
Also, check the config on the remote port as well as as well.
i've checked all the cabling and it's correct. the original error I received was the following. This was on my 4506
%EC-5-DONTBNDL: Gi1/2 suspended: incompatible partner port with Gigabi
tEthernet1/1
On my 4503 I received the following:
05:46:54: %EC-5-DONTBNDL: Gi2/6 suspended: incompatible partner port with Gigabi
tEthernet2/5
However, all the configs are identical!
Thoughts?
2674
