Possible faulty port?
Hi guys,
The hardware in question is a cisco WS-C4506, IOS Version 12.1, module 48 10/100BaseTX (RJ45)
WS-X4148-RJ.
This is a the problem I'm having and tests I have done;
One of the Fast Ethernet port reliability is 153/255 (This stats are showing even though there is no cable connected)
When I connect a cat-5 cable the reliability is still the same but also I don't get a link light showing. (I have tried many cables to make sure I'm not using a faulty one. I have also tried other devices connected to this port.)
I have attached a Fluke tester to the the port in question which shows no errors.
Would you say this is faulty?
Any help would be appreciated
Show int results
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 153/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Last clearing of "show interface" counters 24w2d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1559605 packets input, 110490920 bytes, 0 no buffer
Received 1103 broadcasts, 0 runts, 0 giants, 0 throttles
4761 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
1941656 packets output, 2291679040 bytes, 0 underruns
913876 output errors, 913876 collisions, 0 interface resets
1 lost carrier, 0 no carrier
Re: Possible faulty port?
Have you tried using another port to see if the results are still the same? Also, what type of device are you connecting the port to?
No other ports have the same problem. Also the reliability stays the same even when no device is attached.
Devices I've tested on the port was a laptop, Win2000 Server and a Fluke port tester.
The devices when attached show no link light on the port, almost as if the device was not connected. But under windows networking connectors the status shows connected with the speed and duplex.
There seem to be a high amount of Input/Output errors on the interface. Try clearing the counters and see if the problem persist.
-Robert
I Have same problem in Catalyst 2948 GL3. Still I couldn't do any thing please if there is any solution it will be very appreciated.
I noticed the interface in question is forced to 100Mb/s full duplex. Are the devices you have tried to connect to this interface forced to 100Mb/s full duplex as well?
A duplex mismatch would also explain the collisions this port is seeing.
Althouhg the interface and device/computer that I've tried forced to the 100Mb/s full duplex or other forms , It didn't work. So what can you advice in this case. Thanks.
102
