Webcast-Catalyst9k
Possible issues with Unicast reverse path forwarding in multihomed network
Are there any issues with enabling unicast reverse path forwarding on a partially meshed network? If there are 3 sites, (A, B, C) connected like a triangle, would there be issues with enabling it on site A, if it only connects to Site B to reach Site C when the circuit between A and C goes down? Routing is performed by EIGRP. That way, there really wouldn't be any asymmetric routing.
Re: Possible issues with Unicast reverse path forwarding in mult
Does "A" have full routes? If you're trying to use RPF for security, having a default route pretty much destroys it.
InternetA---A-----B----C-----Internet-C
link between A and C is down.
where is RPF enabled. link between
1)A to B
2) B to A
3)B to C
4)C to B
For Internet Traffic it really depends where is the traffic entering your network and where it will exit.
for Internal traffic RPF should work fine in such scenario
168
