Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Possible Networking Bottleneck
We very intermittently see where devices on the network seem to be starved for network bandwidth. We're looking for a fairly inexpensive piece of equipment that we can attach to the switch at several retail locations that will capture a couple hours worth of IP packets for troubleshooting. Any suggestions other than a sniffer (the one we have doesn't keep enough history based on the IP traffic volume) - Thanks
1 ACCEPTED SOLUTION
Re: Possible Networking Bottleneck
Yes it will. The cool thing about them too is you could leave it in place and throttle the application down to use, lets say 25% of the bandwidth, and that's all they get. I think they are pricey, but you might be able to work with a vendor/reseller and they can do a network assesment for you (that way you don't have to buy the box).
Not sure on the price, but a packeteer (www.packeteer.com) would you show you. You would not see the actual packets, but I assume you're looking for top talkers, top protocols, etc. Depending on your equipment, you could use Netflow too.
HTH and please rate.
Thank you for the reply. I am not a networking specialist (more specialized in software development) but would a packeteer give me enough information to determine which device/application is flooding the network - if that is actually our problem? Thanks again!
Great - appreciate the input.
147
