Possible Port Channel Problem.
Cat 4003 with L3 routing card has been set up with etherchannel as per Cisco's documentation. Issuing the command "Show port channel" gives the result "Not directly connected to switch" on one of the ports. What does this mean and is it a problem?
1 REPLY
Anonymous
N/A
Re: Possible Port Channel Problem.
This is the default behavior, no need to worry about this.
101
