Community Member
Possible to use router serial port with ISDN?
Hi there,
If I had a cisco 1720 router with a serial interface, would it be possible to connect this interface to an ISDN modem and BRI(s) and have it complete a call? Reason I ask is that the router with one serial interface would be cheaper than buying two BRI interfaces.
Thanks - Barry
1 REPLY
Bronze
Re: Possible to use router serial port with ISDN?
This is no problem; configure the serial interface for standard DDR (just as you would an ISDN interface) and this will work fine. The ISDN TA will be responsible for Multilink PPP.
84
