power consumption Cat.2960
Hello!
Is it possible to check current power consumption of Cat.2960.
Maybe it is possible from EXEC or by SNMP request?
Gold
show env
SYSTEM POWER SUPPLY STATUS
Internal Power Supply  Type: AC-POE
Internal Power Supply  12V Output Status: Normal
Internal Power Supply  POE -48V Voltage Status: Normal
External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
Fan 1 OK, Low speed setting
Fan 2 OK, Low speed setting
Fan 3 OK, Low speed setting
Fan 4 OK, Low speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 25 Celsius, Normal
Intake Right temperature: 26 Celsius, Normal
Exhaust Left temperature: 33 Celsius, Normal
Exhaust Right temperature: 30 Celsius, Normal
CPU temperature: 51 Celsius, Normal
Power Supply Unit temperature: 44 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM POWER
Motherboard Components Power consumption = 79.1 W
NM/SM slot 1 Power consumption = 62.1 W
Total System Power consumption is: 141.2 W
Environmental information last updated 00:00:15 ago
Hello. Thanks for answer.
sh env is OK for cat 6500 as example, but in cat. 2960 there is no such output.
WS-C2960-48TT-L for examle:
sh env all
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT
WS-C2960S-24TS-L:
sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 34 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 50 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   <>              <>
There is no information about power consumtion...
Gold
it might be model/IOS feature based.
270
