power of 6509
we are trying to get a UPS for a 6509 switch which has 2 x 3000w PS. can anyone recommend me how much kva ups like 3kva or 5 kva ups can be deployed
Karthik
Aaron Harrison
First you need to work out your power draw:
http://tools.cisco.com/cpc/
Once done try the UPS selector from APC (obviously once you have a spec, you can go elsewhere to buy...).. this will let you specify how much power your kit will draw, and how much runtime you want on UPS etc.
http://www.apc.com/sizing/selectors.cfm
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
hi thanks for the responses that helped me a lot
Karthik
No problem - please remember to rate posts using the stars and mark answered if they are resolved.
Aaron
Ganesh Hariharan
Karthik
Hi Karthik,
Check out the below link hope to help !!
http://www.cisco.com/univercd/cc/td/doc/pcat/ca6000.htm
Remember to rate helpful post
Ganesh.H
