Community Member
power of 6509
we are trying to get a UPS for a 6509 switch which has 2 x 3000w PS. can anyone recommend me how much kva ups like 3kva or 5 kva ups can be deployed
Karthik
1 ACCEPTED SOLUTION
Super Bronze
Re: power of 6509
First you need to work out your power draw:
http://tools.cisco.com/cpc/
Once done try the UPS selector from APC (obviously once you have a spec, you can go elsewhere to buy...).. this will let you specify how much power your kit will draw, and how much runtime you want on UPS etc.
http://www.apc.com/sizing/selectors.cfm
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Re: power of 6509
Aaron
Community Member
Re: power of 6509
hi thanks for the responses that helped me a lot
Karthik
Super Bronze
Re: power of 6509
No problem - please remember to rate posts using the stars and mark answered if they are resolved.
Aaron
Re: power of 6509
Karthik
Hi Karthik,
Check out the below link hope to help !!
http://www.cisco.com/univercd/cc/td/doc/pcat/ca6000.htm
Remember to rate helpful post
Ganesh.H
530
