Power over ethernet on CatX UTP
wmmak
Hi all,
Is PoE dependent on the Cat type of UTP? i.e. can Cat5 support PoE or at least Cat5e?
mak
pkhatri
Level 11
Level 11
PoE will work just fine oer standard Cat5 cabling - that is one of the attractions of PoE. You don't need a forklift upgrade of your cabling to support PoE.
Hope that helps - pls rate the post if it does.
Paresh
pkhatri
Level 11
Level 11
Paresh
