Community Member
Power Spec For the WS-C6509-E Switch
I just need to know where to look for the power requirements for the WS-C6509-E Switch.
Purple
Re: Power Spec For the WS-C6509-E Switch
You might want to check out the Power Calculator here:
http://tools.cisco.com/cpc/ (requires login)
Hope that helps - pls rate the post if it does.
Paresh
Here you go:
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd8017a5e7.html
"• The 6- and 9-slot chassis are designed to scale beyond 4000W power supply configurations. In the future they will support 6000W power supplies.
• The minimum power supply required is 2500W or higher (AC or DC) for the 6- and 9-slot chassis."
HTH,
Bobby
*Please rate helpful posts
1065
