Community Member
PPP Authentication - Problem - Please Help - Thanks
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname castlehill-pip
boot system flash c1700-122-8.T.bin
logging buffered 4096 debugging
enable password 7 xxxxxxxxxxxxx
username syd-cor1 password 7 xxxxxxxxxxx
memory-size iomem 25
clock timezone EST 10
clock summer-time EDST recurring last Sun Oct 2:00 last Sun Mar 3:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
no ip domain-lookup
ip accounting-threshold 1024
isdn switch-type basic-net3
isdn voice-call-failure 0
interface Tunnel0
description Private-IP Tunnel to Head Office
ip address a.b.c.d p.q.r.s
no ip redirects
tunnel source x.y.z.w
tunnel destination d.c.e.f
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
no fair-queue
hold-queue 250 in
interface ATM0.2 point-to-point
description Internet Network
pvc 1/33
ubr 128
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface BRI0
no ip address
encapsulation ppp
dialer rotary-group 0
dialer-group 1
no fair-queue
no cdp enable
interface FastEthernet0
description Local Ethernet segment
ip address x.y.z.w
speed auto
no cdp enable
interface Dialer0
description ISDN link to Connect.com.au
bandwidth 128000
ip address d.c.e.f p.q.r.s
ip access-group 10 in
no ip redirects
encapsulation ppp
dialer in-band
dialer idle-timeout 604800
dialer enable-timeout 5
dialer wait-for-carrier-time 15
dialer map ip x.y.z.w name syd-cor1 broadcast 0282198609
dialer load-threshold 1 outbound
dialer-group 1
no fair-queue
no cdp enable
ppp authentication chap
ppp chap hostname spotlight106-gw
ppp multilink
interface Dialer2
ip address negotiated
encapsulation ppp
dialer pool 2
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname abcd@pqrs
ppp chap password 7 xxxxxxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 10.61.88.200
ip route 172.61.0.0 255.255.0.0 Dialer2
ip route x.x.x.x 255.255.255.255 x.x.x.x
no ip http server
ip pim bidir-enable
access-list 10 permit a.b.c.d
access-list 10 deny any
priority-list 1 protocol ip high lt 100
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
snmp-server community xxxxxxx RO
line con 0
line aux 0
line vty 0 4
exec-timeout 60 0
login
no scheduler allocate
sntp server x.y.z.w
end
This is config of the router. Now apparently when i do a debug ppp auth on this router, its giving me stuff that i was uanble to decipher. please help thanks
*Mar 2 02:38:10.629 UTC: %LINK-3-UPDOWN: Interface Virtual-Access1, changed st
te to up
*Mar 2 02:38:10.629 UTC: %DIALER-6-BIND: Interface Vi1 bound to profile Di2
*Mar 2 02:38:10.629 UTC: Vi1 PPP: Authorization NOT required
*Mar 2 02:38:10.633 UTC: Vi1 PPP: Treating connection as a callout
*Mar 2 02:38:10.633 UTC: Vi1 PPP:Phase is ESTABLISHING, Active Open
*Mar 2 02:38:10.633 UTC: Vi1 PPP:No remote authentication for call-out
*Mar 2 02:38:10.633 UTC: Vi1 LCP:O CONFREQ [Closed] id 209 len 10
*Mar 2 02:38:10.633 UTC: Vi1 LCP:MagicNumber 0x07CEDC83 (0x050607CEDC83)
*Mar 2 02:38:10.641 UTC: Vi1 LCP:I CONFACK [REQsent] id 209 len 10
*Mar 2 02:38:10.641 UTC: Vi1 LCP:MagicNumber 0x07CEDC83 (0x050607CEDC83)
*Mar 2 02:38:10.669 UTC: Vi1 LCP:I CONFREQ [ACKrcvd] id 100 len 34
*Mar 2 02:38:10.669 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:10.669 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:10.669 UTC: Vi1 LCP:MRRU 1524 (0x110405F4)
*Mar 2 02:38:10.669 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:10.673 UTC: Vi1 LCP:O CONFREJ [ACKrcvd] id 100 len 8
*Mar 2 02:38:10.673 UTC: Vi1 LCP:MRRU 1524 (0x110405F4)
*Mar 2 02:38:10.681 UTC: Vi1 LCP:I CONFREQ [ACKrcvd] id 101 len 30
*Mar 2 02:38:10.681 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:10.681 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)xi
castlehill-pip(config)#
*Mar 2 02:38:10.681 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:10.681 UTC: Vi1 LCP: O CONFACK [ACKrcvd] id 101 len 30
*Mar 2 02:38:10.685 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:10.685 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:10.685 UTC: Vi1 LCP: State is Open
*Mar 2 02:38:10.685 UTC: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar 2 02:38:12.625 UTC: %LINK-3-UPDOWN: Interface Dialer2, changed state to u
*Mar 2 02:38:12.625 UTC: Di2 LCP: Not allowed on a Dialer Profile
*Mar 2 02:38:12.677 UTC: Vi1 LCP:I CONFREQ [Open] id 102 len 30
*Mar 2 02:38:12.677 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:12.677 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:12.677 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:12.681 UTC: Vi1 PPP:Phase is TERMINATING
*Mar 2 02:38:12.681 UTC: Vi1 PPP:No remote authentication for call-out
*Mar 2 02:38:12.681 UTC: Vi1 PPP:Phase is ESTABLISHING
*Mar 2 02:38:12.681 UTC: Vi1 LCP:O CONFREQ [Open] id 210 len 10
*Mar 2 02:38:12.681 UTC: Vi1 LCP:MagicNumber 0x07CEE484 (0x050607CEE484)
*Mar 2 02:38:12.685 UTC: Vi1 LCP:O CONFACK [Open] id 102 len 30
*Mar 2 02:38:12.685 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:12.685 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:12.685 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:12.689 UTC: Vi1 LCP:I CONFACK [ACKsent] id 210 len 10
*Mar 2 02:38:12.689 UTC: Vi1 LCP:MagicNumber 0x07CEE484 (0x050607CEE484)
*Mar 2 02:38:12.689 UTC: Vi1 LCP:State is Open
*Mar 2 02:38:12.689 UTC: Vi1 PPP:Phase is AUTHENTICATING, by the peer
*Mar 2 02:38:14.677 UTC: Vi1 LCP:I CONFREQ [Open] id 103 len 30
*Mar 2 02:38:14.677 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:14.677 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:14.677 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F414133230166E3033)
*Mar 2 02:38:14.681 UTC: Vi1 PPP:Phase is TERMINATING
*Mar 2 02:38:14.681 UTC: Vi1 PPP:No remote authentication for call-out
*Mar 2 02:38:14.681 UTC: Vi1 PPP:Phase is ESTABLISHING
*Mar 2 02:38:14.681 UTC: Vi1 LCP:O CONFREQ [Open] id 211 len 10
*Mar 2 02:38:14.681 UTC: Vi1 LCP:MagicNumber 0x07CEEC55 (0x050607CEEC55)
*Mar 2 02:38:14.681 UTC: Vi1 LCP:O CONFACK [Open] id 103 len 30
*Mar 2 02:38:14.685 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:14.685 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:14.685 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:14.689 UTC: Vi1 LCP:I CONFACK [ACKsent] id 211 len 10
*Mar 2 02:38:14.689 UTC: Vi1 LCP:MagicNumber 0x07CEEC55 (0x050607CEEC55)
*Mar 2 02:38:14.689 UTC: Vi1 LCP: State is Open
*Mar 2 02:38:14.689 UTC: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar 2 02:38:16.677 UTC: Vi1 LCP:I CONFREQ [Open] id 104 len 30
*Mar 2 02:38:16.677 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:16.677 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:16.677 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:16.681 UTC: Vi1 PPP:Phase is TERMINATING
*Mar 2 02:38:16.681 UTC: Vi1 PPP:No remote authentication for call-out
*Mar 2 02:38:16.681 UTC: Vi1 PPP:Phase is ESTABLISHING
*Mar 2 02:38:16.681 UTC: Vi1 LCP:O CONFREQ [Open] id 212 len 10
*Mar 2 02:38:16.681 UTC: Vi1 LCP:MagicNumber 0x07CEF426 (0x050607CEF426)
*Mar 2 02:38:16.681 UTC: Vi1 LCP:O CONFACK [Open] id 104 len 30
*Mar 2 02:38:16.685 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:16.685 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:16.685 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:16.689 UTC: Vi1 LCP:I CONFACK [ACKsent] id 212 len 10
*Mar 2 02:38:16.689 UTC: Vi1 LCP:MagicNumber 0x07CEF426 (0x050607CEF426)
*Mar 2 02:38:16.689 UTC: Vi1 LCP:State is Open
*Mar 2 02:38:16.689 UTC: Vi1 PPP:Phase is AUTHENTICATING, by the peer
*Mar 2 02:38:18.677 UTC: Vi1 LCP:I CONFREQ [Open] id 105 len 30
*Mar 2 02:38:18.677 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:18.677 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:18.677 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:18.681 UTC: Vi1 PPP: Phase is TERMINATING
*Mar 2 02:38:18.681 UTC: Vi1 PPP: No remote authentication for call-out
*Mar 2 02:38:18.681 UTC: Vi1 PPP:Phase is ESTABLISHING
*Mar 2 02:38:18.681 UTC: Vi1 LCP:O CONFREQ [Open] id 213 len 10
*Mar 2 02:38:18.681 UTC: Vi1 LCP:MagicNumber 0x07CEFBF7 (0x050607CEFBF7)
*Mar 2 02:38:18.681 UTC: Vi1 LCP:O CONFACK [Open] id 105 len 30
*Mar 2 02:38:18.685 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:18.685 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:18.685 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
*Mar 2 02:38:18.689 UTC: Vi1 LCP:I CONFACK [ACKsent] id 213 len 10
*Mar 2 02:38:18.689 UTC: Vi1 LCP:MagicNumber 0x07CEFBF7 (0x050607CEFBF7)
*Mar 2 02:38:18.689 UTC: Vi1 LCP:State is Open
*Mar 2 02:38:18.689 UTC: Vi1 PPP:Phase is AUTHENTICATING, by the peer
*Mar 2 02:38:20.677 UTC: Vi1 LCP:I CONFREQ [Open] id 106 len 30
*Mar 2 02:38:20.677 UTC: Vi1 LCP:AuthProto CHAP (0x0305C22305)
*Mar 2 02:38:20.677 UTC: Vi1 LCP:MagicNumber 0xB12C2300 (0x0506B12C2300)
*Mar 2 02:38:20.677 UTC: Vi1 LCP:EndpointDisc 1 Local (0x130F016E504F41413
3230166E3033)
Silver
Re: PPP Authentication - Problem - Please Help - Thanks
Apparently your problem is that of authentication. The other side is trying to AUTH you, but you are not expecting it. Your BRI0 doesn't have ppp auth statement.
You can also remove all auth statements and once link is up, introduce them again.
Community Member
its not the bri that is the problem. its the dialer2 that is the problem - the adsl connection.thx
Silver
paste in the config from the remote router
Community Member
the remote router is the uac. IT TERMINATES ONTHE ISP AND I CANT GET IT:). I USED THE SAME CONFIG ON OTHER PLACES OF THE SAME COMPANY AND THE WORKED.
Silver
as stated in the earlier post it looks like the remote end is not configured for authentication , remove auth on your side , if the link comes up it proves the remote router is misconfigured.
Community Member
Since the debug output does not have any "auth-req" or "chap", this means that both parties are still negotiating.Your router has acknowledged that it can use chap based on the config request sent by the remote end.
You can try the "ppp timeout retry 20" on the dialer interface,this will increase the timeout. But what concerns me is that after the LCP phase is open and after
The negotiations after this should include a challenge sent by the remote end something like : CHAP: I CHALLENGE id ....
Well I'm not sure if it is possible to associate a dialer interface to a physical sub-interface atm0.x
I'm really interested to know what is going on!!
Jawad
Good Luck
Bronze
Are you trying to using the bri or the atm ? The trace shows dialer2 which is the atm.
Community Member
I am tryin gto use the atm. the bri is working fine.
its the atm which is gving me the problem
128
