Community Member
ppp Callback on same card?
We will have a 3660 with an E1 and digital modem card(NM-1CE1U and NM-30DM) and also an NM-8AM. Both of these will have a discrete hunt group number. Is it possible to configure callback whereby if you dial into the analogue modems callback will only be performed by the analogue modems and equally if you dial into the PRI(analogue or digital) callback will be only performed by the PRI. If you can do such a thing what would a config look like? Any help would be much appreciated.
Cheers,
Marcus.
Bronze
Re: ppp Callback on same card?
Under the NM-8AM lines configure "no modem dialout controller E1 slot/port", and under the remaining lines configure "modem dialout controller E1 slot/port"; this should prevent 8AM calls from trying to use the controller (PRI) while allowing the 30DM to use it.
Community Member
Mmm. the documentation seems to state that is only supported on the ASxxxx boxes. I just went into a 3660 and this command didn't seem to be available. Do you think there might be another way to do this?
Cheers.
Bronze
This command was extended to the 3600 with CSCdm42742; however, you'll need the latest 12.2T code to get this.
Community Member
Thanks very much Mark.
90
