PPP multilink, big problem
Hello.
I have two routers, one 7206VXR and one 3661.
They are interconected by 6 E1 links.
I configured ppp multilink, and use static routes, at this moment everything is OK.
I have in 3661´s Lan two video source, one Mpeg1 at 2Mb, and another Mpeg2 at 4 Mb, transmiting both on UDP (multicast traffic) whith different Destination IP and Port.
I configured pim sparse-mode and everything still OK.
In the central Site when I subscribe a multicast group to see the video the video looks horrible, with multiples "artefacts" (loss packet). I tried some things, like make a tunnel, virtual templates, and same result.
I tried to subscribe just 2Mb video and leave the multilink limit to 2 E1(4 Mb), the video looks perfect, but when i Begin to add phisical interfaces to multilink group, the video decrease quality. I think this is for the way that multilink works with packets, there are many,many, reorodered on sh ppp multilink command.
When I trie with the 4Mb video the results are the same, i tried too leave just three phisical interfaces on multilink, but the video quality is very poor.
Any comments will be apreciated.
Thanks in advance.
How can i do to increase video performance ?
Re: PPP multilink, big problem
Nobody have any idea ?
I dont explain myself right ?
Need more data ?
Help me ! please !!!
hi
can u chck the reliability of other E1s? may be due to which u r getting the packet drops once u bundle them up.
prem
Thanks !
I saw statistics on the physical port, but they are OK, no drops, no flush, in the serial interfaces nothing wrong aparently.
But in the interface multilink:
Router-CMC-MA#sh ppp multilink inte multilink 1
Multilink1, bundle name is router-es1-ma
Bundle up for 1d11h, 1/255 load
Receive buffer limit 73152 bytes, frag timeout 1000 ms
132/0 fragments/bytes in reassembly list
1573 lost fragments, 473819 reordered
25/627142 discarded fragments/bytes, 26 lost received
0x167425 received sequence, 0x130F5E sent sequence
Member links: 6 active, 0 inactive (max not set, min not set)
Se1/1, since 1d11h
Se1/3, since 21:23:57
Se2/1, since 1d11h
Se1/0, since 1d11h
Se1/2, since 21:24:05
Se2/0, since 1d11h
Can you see something here to help ?
Thanks again !
Bronze
MLPPP is CPU intensive. What's the router utilization look like as you add circuits? Also, the data can only flow as fast as the slowest circuit because of the round robin and fragmentation. Test response time on each circuit and see if one is a lot slower than the others.
Can you paste your configs...
Do you have CEF running on your routers.
Silver
Have you tried to interleave your packets with PPP multilink interleave ?
int virtual template 1
encap ppp
ppp multilink interleave
int Se1/1
ppp multilink group-member 1
Se1/3
int Se2/1
int Se1/0
int Se1/2
int Se2/0
This will interleave video with the larger data packets
146
