PPP Multilink problems with both isdn b channel up
I've experienced these problems everytime I enable dual b channel of the ISDN to connect to the Internet.
The commands that I used are
interface bri0
dialer load-threshold 1 either -> because I want both channel to be up all the time
ppp multilink
With both channel up I found the following problems :
1. If I send large attachment with outlook express it will be stopped halfway
2. Lotus notes behind my router failed to replicate its database to the other lotus notes server in the internet.
3. Microsoft terminal services server some time have problem to be accessed if the client is behind my router.
I've already tested using other cisco router with the same result, but the above problems will be solved if I drop one b channel. Strange thing is if I tried using ISDN modem or other ISDN router with both channel up there won't be any problem.
1 REPLY
Re: PPP Multilink problems with both isdn b channel up
Try using dialer profiles on this interface as it might solve your problem
78
