03-07-2002 05:43 AM - edited 03-01-2019 08:47 PM
HI i have an issue with PPP multilink.
It seems when i use Windows 98/95 PPP multilink does not work it only connects at 64000kbps when i press the resume button to intiate mutilink it does not initate the second channel. I can get this to work with win 2000 but on intial configuration win 2000 bundles the channels as default and not by pressing the resume button. so it connects directly as 128kbps. Now this would point to the windows 98 client not configured right but we have a us robotics dialin server and this connects at 64kbps then at 128kbps when u press the resume button, so it not the client. pls help i have tried everything. i have 3640 with c3640-is-mz.122-7a.bin ios this is the ip pus software with nm60dm card plus isdn30 combo card. the configuration looks fine to me cheers for any help
here the config
aaa new-model
aaa authentication login default group radius local
aaa authentication login NO_AUTHEN none
aaa authentication login VTYLINE enable
aaa authentication ppp default group radius none
aaa authorization network defaut group radius if-authenticated
enable secret 5 $1$qJOI$xh5DyZACAhN.IdoWhOPnf1
username admin callback-dialstring "" password 7 15010E19173E2E36
username newham\darvin1 password 7 110D1817011B055D
memory-size iomem 15
clock timezone gmt 0
ip subnet-zero
isdn switch-type primary-net5
call rsvp-sync
controller E1 0/0
pri-group timeslots 1-31
controller E1 0/1
pri-group timeslots 1-8,16
interface Serial0/0:15
no ip address
encapsulation ppp
dialer rotary-group 1
isdn incoming-voice modem
no cdp enable
ppp multilink
interface Serial0/1:15
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface FastEthernet3/0
ip address
interface Group-Async0
ip unnumbered FastEthernet3/0
encapsulation ppp
async mode interactive
peer default ip address pool dhcpclient
ppp callback accept
ppp authentication ms-chap chap
group-range 33 62
interface Group-Async1
encapsulation ppp
ppp callback accept
group-range 65 94
interface Dialer1
encapsulation ppp
dialer in-band
dialer idle-timeout 3000
dialer load-threshold 1 outbound
ppp callback accept
ppp authentication chap ms-chap
ppp multilink
radius-server host 111.113.101.2 auth-port 1645 acct-port 1646 key 7 15010E01053A232B3A36
dial-peer cor custom
03-07-2002 12:18 PM
Try collecting the following debug to try and figure out what is going wrong:
debug ppp neg
debug ppp mult event
debug dialer
debug isdn q931
03-11-2002 06:21 AM
I HAVE TRIED all this before and still no joy. still cant read any problems from the debug maybe u can.
i have some also done some show commands
show ppp multilink
Virtual-Access1, bundle name is NEWHAM\dappanah
Bundle up for 00:03:22
Dialer interface is Dialer1
0 lost fragments, 0 reordered, 0 unassigned
0 discarded, 0 lost received, 1/255 load
0x168 received sequence, 0x0 sent sequence
Member links: 1 (max not set, min not set)
Serial0/0:0, since 00:03:22, last rcvd seq 000167
BRIREMOTEDIAL#show ppp queu
Proc #0 pid=2
authens =134 avg=5 s.
per-user=748 avg=0 s.
preauth =0 avg=0 s.
authors =0 avg=0 s.
queue len=0 max len=4
BRIREMOTEDIAL#show
*Mar 7 02:38:32: Vi1 MLP: Load (1) above threshold in bundle NEWHAM\darvinappanah
% Type "show ?" for a list of subcommands
BRIREMOTEDIAL#how show dialer aler
Serial0/0:0 - dialer type = ISDN
Idle timer (3000 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is multilink member (NEWHAM\darvinappanah)
Serial0/0:1 - dialer type = ISDN
Dialer state is idle
Serial0/0:2 - dialer type = ISDN
Serial0/0:3 - dialer type = ISDN
Serial0/0:4 - dialer type = ISDN
BRIREMOTEDIAL#show dialer maps
Dynamic dialer map ip 151.133.101.98 name NEWHAM\darvinappanah () on Di1
*Mar 7 02:34:59: ISDN Se0/0:15: RX <- SETUP pd = 8 callref = 0x0001
*Mar 7 02:34:59: Sending Complete
*Mar 7 02:34:59: Bearer Capability i = 0x8890
*Mar 7 02:34:59: Channel ID i = 0xA98381
*Mar 7 02:34:59: Called Party Number i = 0x81, '345766', Plan:ISDN, Type:Unknown
*Mar 7 02:34:59: Low Layer Compat i = 0x8890
*Mar 7 02:34:59: ISDN Se0/0:15: llc valid, speed 64, call type is DATA
speed:0 async:N
*Mar 7 02:34:59: %LINK-3-UPDOWN: Interface Serial0/0:0, changed state to up
*Mar 7 02:34:59: Se0/0:0 PPP: Treating connection as a callin
*Mar 7 02:34:59: Se0/0:0 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 0 load]
*Mar 7 02:34:59: Se0/0:0 LCP: State is Listen
*Mar 7 02:34:59: ISDN Se0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8001
*Mar 7 02:34:59: ISDN Se0/0:15: TX -> CONNECT pd = 8 callref = 0x8001
*Mar 7 02:34:59: ISDN Se0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0001
*Mar 7 02:34:59: ISDN Se0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x9A, bchan 0, dsl 0
*Mar 7 02:34:59: Se0/0:0 LCP: I CONFREQ [Listen] id 1 len 46
*Mar 7 02:34:59: Se0/0:0 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Mar 7 02:34:59: Se0/0:0 LCP: MagicNumber 0x000AEE34 (0x0506000AEE34)
*Mar 7 02:34:59: Se0/0:0 LCP: PFC (0x0702)
*Mar 7 02:34:59: Se0/0:0 LCP: ACFC (0x0802)
*Mar 7 02:34:59: Se0/0:0 LCP: Callback 6 (0x0D0306)
*Mar 7 02:34:59: Se0/0:0 LCP: MRRU 1500 (0x110405DC)
*Mar 7 02:34:59: Se0/0:0 LCP: EndpointDisc 1 Local
*Mar 7 02:34:59: Se0/0:0 LCP: (0x1313017403000033EE0A0070FD4EC140)
*Mar 7 02:34:59: Se0/0:0 LCP: (0x180000)
*Mar 7 02:34:59: Se0/0:0 LCP: O CONFREQ [Listen] id 55 len 35
*Mar 7 02:34:59: Se0/0:0 LCP: AuthProto MS-CHAP (0x0305C22380)
*Mar 7 02:34:59: Se0/0:0 LCP: MagicNumber 0x27956698 (0x050627956698)
*Mar 7 02:34:59: Se0/0:0 LCP: MRRU 1524 (0x110405F4)
*Mar 7 02:34:59: Se0/0:0 LCP: EndpointDisc 1 BRIREMOTEDIAL (0x13100142524952454D4F54454449414C)
*Mar 7 02:34:59: Se0/0:0 LCP: O CONFACK [Listen] id 1 len 46
*Mar 7 02:34:59: Se0/0:0 LCP: I CONFACK [ACKsent] id 55 len 35
*Mar 7 02:34:59: Se0/0:0 LCP: State is Open
*Mar 7 02:34:59: Se0/0:0 PPP: Phase is AUTHENTICATING, by this end [0 sess, 0 load]
*Mar 7 02:34:59: Se0/0:0 MS-CHAP: O CHALLENGE id 35 len 26 from "BRIREMOTEDIAL"
*Mar 7 02:34:59: Se0/0:0 MS-CHAP: I RESPONSE id 35 len 74 from "NEWHAM\darvinappanah"
*Mar 7 02:34:59: Se0/0:0 MS-CHAP: O SUCCESS id 35 len 4
*Mar 7 02:34:59: Se0/0:0 DDR: Authenticated host NEWHAM\dppanah with no matching dialer map
*Mar 7 02:34:59: Se0/0:0 MCB: Callback not authorized for this user NEWHAM\dappanah
*Mar 7 02:34:59: Serial0/0:0 PPP: O MCB Request(1) id 28 len 6
*Mar 7 02:34:59: Serial0/0:0 MCB: O 1 1C 0 6 1 2
*Mar 7 02:34:59: Se0/0:0 MCB: O Request Id 28 Callback Type None
*Mar 7 02:34:59: Se0/0:0 PPP: Phase is CBCP [0 sess, 0 load]
*Mar 7 02:34:59: Serial0/0:0 PPP: I MCB Response(2) id 28 len 6
*Mar 7 02:34:59: Serial0/0:0 MCB: I 2 1C 0 6 1 2
*Mar 7 02:34:59: Se0/0:0 MCB: Received response
*Mar 7 02:34:59: Se0/0:0 MCB: Response CBK-None 1 2
*Mar 7 02:34:59: Serial0/0:0 PPP: O MCB Ack(3) id 29 len 6
*Mar 7 02:34:59: Serial0/0:0 MCB: O 3 1D 0 6 1 2
*Mar 7 02:34:59: Se0/0:0 MCB: O Ack Id 29 Callback Type None
*Mar 7 02:34:59: Se0/0:0 MCB: No Callback negotiated; Exit
*Mar 7 02:34:59: Se0/0:0 MLP: Request add link to bundle
*Mar 7 02:34:59: Se0/0:0 PPP: Phase is VIRTUALIZED [0 sess, 0 load]
*Mar 7 02:34:59: Se0/0:0 MLP: Adding link to bundle
*Mar 7 02:34:59: Vi1 PPP: Phase is DOWN, Setup [0 sess, 0 load]
*Mar 7 02:34:59: Vi1 PPP: No remote authentication for call-in
*Mar 7 02:34:59: Vi1 PPP: Phase is ESTABLISHING [0 sess, 0 load]
*Mar 7 02:34:59: Vi1 MLP: Added to huntgroup Di1
*Mar 7 02:34:59: Vi1 MLP: Clone from Di1
*Mar 7 02:34:59: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 7 02:34:59: Vi1 DDR: Dialer statechange to up
*Mar 7 02:34:59: Vi1 DDR: Dialer received incoming call from
*Mar 7 02:34:59: Vi1 PPP: Treating connection as a callin
*Mar 7 02:34:59: Vi1 LCP: State is Listen
*Mar 7 02:34:59: Vi1 DDR: Authenticated host NEWHAM\darvinappanah with no matching dialer map
*Mar 7 02:34:59: Vi1 PPP: Phase is UP [0 sess, 0 load]
*Mar 7 02:34:59: Vi1 IPCP: O CONFREQ [Closed] id 1 len 10
*Mar 7 02:34:59: Vi1 IPCP: Address 151.133.101.1 (0x030697856501)
*Mar 7 02:34:59: Vi1 MLP: Added first link Se0/0:0 to bundle NEWHAM\dappanah
*Mar 7 02:35:00: Vi1 IPCP: I CONFREQ [REQsent] id 1 len 40
*Mar 7 02:35:00: Vi1 IPCP: CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
*Mar 7 02:35:00: Vi1 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 7 02:35:00: Vi1 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar 7 02:35:00: Vi1 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
*Mar 7 02:35:00: Vi1 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar 7 02:35:00: Vi1 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
*Mar 7 02:35:00: Vi1 IPCP: Pool returned 151.133.101.98
*Mar 7 02:35:00: Vi1 IPCP: O CONFREJ [REQsent] id 1 len 22
*Mar 7 02:35:00: Vi1 IPCP: I CONFACK [REQsent] id 1 len 10
*Mar 7 02:35:00: Vi1 IPCP: Address 151.133.101.1 (0x030697856501)
*Mar 7 02:35:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:0, changed state to up
*Mar 7 02:35:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Mar 7 02:35:01: Vi1 IPCP: TIMEout: State ACKrcvd
*Mar 7 02:35:01: Vi1 IPCP: O CONFREQ [ACKrcvd] id 2 len 10
*Mar 7 02:35:01: Vi1 IPCP: Address 151.133.101.1 (0x030697856501)
*Mar 7 02:35:02: Vi1 IPCP: I CONFACK [REQsent] id 2 len 10
*Mar 7 02:35:02: Vi1 IPCP: Address 151.133.101.1 (0x030697856501)
*Mar 7 02:35:02: Vi1 MLP: Load (1) above threshold in bundle NEWHAM\darvinappanah
*Mar 7 02:35:03: Vi1 IPCP: I CONFREQ [ACKrcvd] id 2 len 34
*Mar 7 02:35:03: Vi1 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 7 02:35:03: Vi1 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar 7 02:35:03: Vi1 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
*Mar 7 02:35:03: Vi1 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar 7 02:35:03: Vi1 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
*Mar 7 02:35:03: Vi1 IPCP: O CONFREJ [ACKrcvd] id 2 len 16
*Mar 7 02:35:03: Vi1 IPCP: I CONFREQ [ACKrcvd] id 3 len 22
*Mar 7 02:35:03: Vi1 IPCP: O CONFNAK [ACKrcvd] id 3 len 22
*Mar 7 02:35:03: Vi1 IPCP: Address 151.133.101.98 (0x030697856562)
*Mar 7 02:35:03: Vi1 IPCP: PrimaryDNS 151.133.103.30 (0x81069785671E)
*Mar 7 02:35:03: Vi1 IPCP: PrimaryWINS 151.133.75.200 (0x820697854BC8)
*Mar 7 02:35:03: Vi1 IPCP: I CONFREQ [ACKrcvd] id 4 len 22
*Mar 7 02:35:03: Vi1 IPCP: O CONFACK [ACKrcvd] id 4 len 22
*Mar 7 02:35:03: Vi1 IPCP: State is Open
*Mar 7 02:35:03: Vi1 DDR: dialer protocol up
*Mar 7 02:35:03: Di1 IPCP: Install route to 151.133.101.98
*Mar 7 02:35:05: %ISDN-6-CONNECT: Interface Serial0/0:0 is now connected to NEWHAM\dappanah
*Mar 7 02:35:32: Vi1 MLP: Load (1) above threshold in bundle NEWHAM\darvinappanah
*Mar 7 02:36:02: Vi1 MLP: Load (1) above threshold in bundle NEWHAM\darvinappanah
*Mar 7 02:36:32: Vi1 MLP: Load (7) above threshold in bundle NEWHAM\darvinappanah
*Mar 7 02:37:02: Vi1 MLP: Load (39) above threshold in bundle NEWHAM\darvinappanah
*Mar 7 02:37:32: Vi1 MLP: Load (23) above threshold in bundle NEWHAM\darvinappanah
03-11-2002 12:26 PM
We are not seeing a second call incoming.
At 02:34:59 we recieve the first call; it is established (ISDN and PPP) at 02:35:03. The messages you see after that are simply an indication that the load-threshold (which you have configured as 1) has been met or exceeded; however, since this side only receives calls we cannot dial out. The debug lasts for 150 seconds after the initial call, yet we do NOT see an ISDN Q.931 SETUP message incoming...therefore, we don't know about any second call. I suspect the client is not dialing out; I can't tell you why this works with non-cisco
equipment.
