Bronze
ppp over frame relay question
Does anyone know if the ppp quality command works on a circuit setup for ppp over frame relay?
Also, the frame circuit is currently a p2p subinterface. Can ppp over f/r be done on an individual subinterface and not on the others?
1 REPLY
Bronze
Re: ppp over frame relay question
Well I guess no one likes my question. Heres some added info.
I found some examples in cisco docs that used ppp quality on frame relay sub-interfaces. But I cant get it to work. I set it up in my lab like this. This is just a lab so dont worry about hiding the addresses.
! R2
interface Virtual-Template1
ip address 10.1.4.2 255.255.255.0
interface Virtual-Template2
ip address 10.1.5.2 255.255.255.0
interface Serial0
no ip address
encapsulation frame-relay
interface Serial0.1 point-to-point
frame-relay interface-dlci 104 ppp Virtual-Template1
interface Serial0.2 point-to-point
frame-relay interface-dlci 105 ppp Virtual-Template2
interface Serial0.3 point-to-point
ip address 10.1.6.2 255.255.255.0
frame-relay interface-dlci 106
! R5!
interface Serial0
no ip address
frame-relay interface-dlci 501 ppp Virtual-Template1
It works like this but as soon as I add the command
ppp quality 80
to either side or both sides the link goes down.
Debug ppp packets is on
00:33:33: Vi1 PPP: O pkt type 0x0021, datagramsize 72
00:33:33: Vi1 PPP: I pkt type 0x0021, datagramsize 72
r4(config)#int virtual-te 1 „²---virtual template1
r4(config-if)#ppp quali
00:33:43: Vi1 PPP: O pkt type 0x0021, datagramsize 72
00:33:43: Vi1 PPP: I pkt type 0x0021, datagramsize 72
r4(config-if)#ppp quality 80 „²----set quality
r4(config-if)#
00:33:46: Vi1 LCP: O CONFREQ [Closed] id 3 len 18
00:33:46: Vi1 LCP: QualityType 0xC025 period 1000 (0x0408C025000003E8)
00:33:46: Vi1 LCP: MagicNumber 0x109A6CC9 (0x0506109A6CC9)
00:33:46: Vi1 PPP: I pkt type 0xC021, datagramsize 14
00:33:46: Vi1 PPP: I pkt type 0xC021, datagramsize 22
00:33:46: Vi1 LCP: I CONFREQ [REQsent] id 13 len 10
r4(config-if)# ---- LQRs start here
00:33:56: Vi1 LQM: O state Open magic 0x109A6CC9 len 48
00:33:56: Vi1 LQM: LastOutLQRs 0 LastOutPackets/Octets 0/0
00:33:56: Vi1 LQM: PeerInLQRs 0 PeerInPackets/Discards/Errors/Octets 0/0/0/0
00:33:56: Vi1 LQM: PeerOutLQRs 1 PeerOutPackets/Octets 241/32225
00:33:56: Vi1 PPP: I pkt type 0xC025, datagramsize 52
00:33:56: Vi1 LQM: I state Open magic 0xE0CE862E len 48
00:33:56: Vi1 LQM: LastOutLQRs 1 LastOutPackets/Octets 241/32225
00:33:56: Vi1 LQM: PeerInLQRs 1 PeerInPackets/Discards/Errors/Octets 240/0/0/1
6044
00:33:56: Vi1 LQM: PeerOutLQRs 1 PeerOutPackets/Octets 1185/91773
00:34:46: Vi1 LQM: PeerOutLQRs 6 PeerOutPackets/Octets 1219/94415
00:34:46: Vi1 IPCP: O TERMREQ [Open] id 3 len 4
r4(config-if)#
00:34:46: Vi1 PPP: I pkt type 0x8021, datagramsize 8
00:34:46: Vi1 IPCP: I TERMACK [Closed] id 3 len 4
-----50 seconds later it goes down -------
r4(config-if)#
00:34:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, change
d state to down
00:34:47: %OSPF-5-ADJCHG: Process 1, Nbr 10.1.6.2 on Virtual-Access1 from FULL to
DOWN, Neighbor Down: Interface down or detached
This is lab. It doesn¡¦t have a quality problem. Does anyone know whats going on??? When I try the same thing on a point to point serial circuit it stays up.
107
