11-07-2001 11:00 AM - edited 03-01-2019 07:17 PM
I have problem with one serial lines.
The link it worked properly, but when I try to use the ppp reliable-link
command in the serial line configuration, the link is going down, and then
it's never becomme up with initial configuration.
On the other side I don't have in configuration this line:
ppp reliable-link
This is the configuration:
Cisco 7513
interface Serial9/5
bandwidth 64
ip address 193.231.142.41 255.255.255.252
encapsulation ppp
no ip mroute-cache
keepalive 20
no peer default ip address
no fair-queue
no cdp enable
end
Cisco 2610:
interface Serial0/0
bandwidth 64
ip address 193.231.142.42 255.255.255.252
no ip directed-broadcast
encapsulation ppp
keepalive 20
no fair-queue
The problem was when I put on the 7513 the ppp reliable-link command in
configuration.
I listed here the debug ppp negociation on the 7513 side:
2d03h: Se9/5 PPP: Phase is ESTABLISHING, Passive Open [0 sess, 1 load]
2d03h: Se9/5 LCP: State is Listen
2d03h: Se9/5 LCP: I CONFREQ [Listen] id 39 len 10
2d03h: Se9/5 LCP: MagicNumber 0x057B9F39 (0x0506057B9F39)
2d03h: Se9/5 LCP: O CONFREQ [Listen] id 57 len 10
2d03h: Se9/5 LCP: MagicNumber 0x9BA2296A (0x05069BA2296A)
2d03h: Se9/5 LCP: O CONFACK [Listen] id 39 len 10
2d03h: Se9/5 LCP: I CONFACK [ACKsent] id 57 len 10
2d03h: Se9/5 LCP: MagicNumber 0x9BA2296A (0x05069BA2296A)term
2d03h: Se9/5 LCP: State is Open
2d03h: Se9/5 PPP: Phase is UP [0 sess, 1 load]
2d03h: Se9/5 LEXCP: O CONFREQ [Closed] id 19 len 4
2d03h: Se9/5 IPCP: O CONFREQ [Closed] id 19 len 10
2d03h: Se9/5 IPCP: Address 193.231.142.41 (0x0306C1E78E29) no
2d03h: Se9/5 CDPCP: O CONFREQ [Closed] id 18 len 4
2d03h: Se9/5 LCP: I TERMREQ [Open] id 40 len 4
2d03h: Se9/5 LCP: O TERMACK [Open] id 40 len 4
2d03h: Se9/5 LEXCP: State is Closed
2d03h: Se9/5 IPCP: State is Closed
2d03h: Se9/5 CDPCP: State is Closed
2d03h: Se9/5 PPP: Phase is TERMINATING [0 sess, 1 load]mon
2d03h: Se9/5 LCP: TIMEout: State TERMsent
2d03h: Se9/5 LCP: State is Closed
Please suggest me something.
Thx in advance
Otto
11-11-2001 07:15 PM
try putting "no cdp enable" command in serial interface of both the routers,
let me know if it works
11-15-2001 08:57 AM
The solution was no encapsulation ppp, and I use the hdlc encapsulation.
I try with disabled cdp but it's not worked.
Anyway thx :)
