11-13-2002 06:03 PM - edited 03-02-2019 02:52 AM
I am trying to connect two 1600's together using PPP over X25 on ISDN dchannel using the AODI method. The following two configs are the client and server running configs of each router (client first). I keep getting this error (Pending on AODI dialer) in debug and this (%ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 82 changed to down) indicating the x25 vc is not working. Isdn status show MULTIPLE_FRAME_ESTABLISHED.
Any help on this would be great.
Ed
Client Router Config
ip subnet-zero
isdn switch-type basic-net3
x25 routing
interface Ethernet0
no ip directed-broadcast
interface Serial0
ip address 10.24.111.2 255.255.255.252
no fair-queue
clockrate 2000000
interface BRI0
no ip address
encapsulation ppp
dialer rotary-group 0
dialer-group 1
isdn x25 dchannel
interface BRI0:0
no ip address
x25 address 4923923
x25 htc 4
x25 win 3
x25 wout 3
x25 aodi
x25 map ppp 4923070 interface Dialer0
interface Dialer0
ip address 172.16.12.2 255.255.255.252
encapsulation ppp
dialer in-band
dialer string 4923070
dialer-group 1
ppp multilink bap
ppp bap call request
ppp bap timeout pending 20
ip classless
ip route 0.0.0.0 0.0.0.0 10.24.111.1
ip route 172.16.13.0 255.255.255.0 172.16.12.1
dialer-list 1 protocol ip permit
no cdp run
Server Router Config
ip subnet-zero
no ip domain-lookup
x25 routing
interface Loopback0
ip address 172.16.13.1 255.255.255.0
interface Ethernet0
ip address 10.24.110.2 255.255.255.0
interface Serial0
ip address 10.24.111.1 255.255.255.252
no ip mroute-cache
interface BRI0
no ip address
encapsulation ppp
no ip mroute-cache
dialer-group 1
isdn x25 dchannel
interface BRI0:0
no ip address
no ip mroute-cache
x25 address 4923070
x25 htc 4
x25 win 3
x25 wout 3
x25 map ppp 4923923 no-outgoing interface Dialer0
interface Dialer0
ip address 172.16.12.1 255.255.255.252
encapsulation ppp
ppp multilink bap
ppp multilink idle-link
ppp bap call accept
ppp bap number default 4923070
router eigrp 100
network 10.0.0.0
ip classless
ip route 192.168.1.0 255.255.255.0 172.16.12.2
no ip http server
no cdp run
11-19-2002 11:36 AM
Try configuring static TEI using the command "isdn x25 static-tei
Since the TEI value is not getting assigned dynamically in your case ,i think if we configure the TEI stattically,it should work.
For configuration guidelines go through the following URL:
