11-20-2003 02:21 AM - edited 03-02-2019 11:51 AM
Hi all,
I've a Cisco Router 1720 connected to a Cisco 5400 NAS via an E1.....The E1
is connected from one side to the Router's serial interface and from the
other side to the NAS controller E1 7/5
Router config
int s0
en ppp
ip add 172.31.19.161 255.255.255.252
NAS config
controller E1 7/5
framing NO-CRC4
channel-group 0 timeslots 1-31
interface Serial7/5:0
ip address 172.31.19.162 255.255.255.252
encapsulation ppp
The problem is that I've the controller E1 7/5 up and interface Serial7/5:0
up/up and the Router's s0 is also up/up but the ping fails on that
interface.
Can anyone suggest why the ping didn't work although L1 and L2 are up.
Komy
11-20-2003 03:10 AM
It will not work.
One side Channelised E1 (NAS) other side unframed E1(serial at 1721)
You require either both the sides unframed/framed-channelised E1.
11-20-2003 03:16 AM
But how come that both sides are up/up which mean that both L1 and L2 are up....plz advise
11-21-2003 10:34 PM
Is there a TELCO provider inbetween Router and NAS.
Else are you using any CSU (modem) or directly connected ?
Can you paste the diagram of connectivity ?
