07-25-2006 03:19 AM - edited 03-03-2019 04:12 AM
I've one router 1721 and your s0 is x.x.x.6/30, the serial of telco is x.x.x.5/30, the fast of my router is y.y.y.y/26.
The encapsulation ppp was configured, my router ping the router broadband telco and internet, the broadband ping my router but the host of my local network not ping internet and not ping serial of broadband router but broadband router ping the host.
The hosts of LAN ping serial 0 of the 1721.
What's problem?
Router(config)#ip route 0.0.0.0 0.0.0.0 x.x.x.5
Router(config)# int fa 0
Router(config-if)#ip add y.y.y.129 255.255.255.192
Router(config-if)#no shut
Router(config)# int s 0
Router(config-if)#ip add x.x.x.6 255.255.255.252
Router(config-if)#encapsulation ppp
07-25-2006 03:22 AM
It appears that your provide is missing a static route for your LAN subnet, pointing to your serial link.
Paresh
07-25-2006 03:33 AM
In addition to Paresh's comment i would like to add if you are not using public ip space then you need to think off configuring NAT in your box.
If thts not the case as suggested reverse route for your local lan space may not be there in your SP side..
regds
07-25-2006 03:47 AM
Who does NAT is the firewall, directly connected in the router. I've a pool address public.
For the test, a notebook directly connected using a public ip no ping in the router telco but the router telco ping the notebook.
07-25-2006 06:47 AM
The SP supplied error range of public ip.
Ufff!
07-25-2006 06:52 AM
Its a silly question but Firewall is between router and internet connection, isnt it?
If Firewall is in DMZ, you have to add a route to point
to Firewall...
07-26-2006 05:39 AM
Hi zerozerotito
The configuration is correct. Problem resolved.
The topology is this:
SP <---->* My router *<--->*(Firewall(NAT))#<--->#LAN
*ip public address
#ip private address
