PPP routing issue
I have a client who has the following setup. network_1 (10.166.53.0) on this network is a 1601-R with a T1 for internet. behind that 1601 is a firewall (10.166.53.101). Everyone on network_1 sees internet fine. They also have 2 1601-R's that are set up with a T1 between them thro the serial1 interface. RouterA has an eth0 address of 10.166.53.251 and a serial1 interface of 10.10.10.1/30. RouterB has an eth0 of 10.26.7.251 and a serial1 interface of 10.10.10.2/30. From RouterA I can ping both of the interfaces on RouterB. But nothing past eth0 on RouterB (IE 10.26.7.194). When I do traceroute it stops at 10.10.10.2
The following is the configs from the 2 routers.
RouterA
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service tcp-small-servers
no service udp-small-servers
hostname GMC
enable password silver
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
interface Ethernet 0
no shutdown
description connected to EthernetLAN
ip address 10.166.53.251 255.255.255.0
keepalive 10
interface Serial 0
no description
no ip address
shutdown
interface Serial 1
no shutdown
description connected to Dodge
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 remote-loopback full
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
ip address 10.10.10.1 255.255.255.252
encapsulation ppp
router rip
version 2
network 10.0.0.0
no auto-summary
ip classless
no ip http server
snmp-server community public RO
no snmp-server location
no snmp-server contact
line console 0
exec-timeout 0 0
password silver
login
line vty 0 4
password silver
login
end
RouterB
hostname Dodge
no ip name-server
ip subnet-zero
no ip domain-lookup
ip routing
no shutdown
description connected to EthernetLAN_1
ip address 10.26.7.251 255.255.255.0
keepalive 10
interface Serial 0
no description
no ip address
shutdown
interface Serial 1
no shutdown
description connected to GMC
ip address 10.10.10.2 255.255.255.252
encapsulation ppp
router rip
version 2
network 10.0.0.0
no auto-summary
ip classless
no ip http server
line console 0
exec-timeout 0 0
password silver
login
line vty 0 4
password silver
login
end
I have been stumped for a couple of days now any help appreciated.
Re: PPP routing issue
Make sure that 10.26.7.194 and all devices connected to routerB Ethernet are configured with RIP or with a default gateway pointing at router B (10.26.7.251).
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
As you can ping Router B's ethernet interface (10.26.7.251) but nothing else on that network, i would suggest that the hosts behind Router B need they're default gateway set to router B.
Good luck
Teggs
93
