PPPOE - DNS problem
I have setup the PPPOE on my 3620 router. But I am having some problem with my DNS, my DSL service is through Verizon, the way I have setup before with the Linksys router is working fine, the Linksys router will automaticlly obtain the IP address and DNS server IP address with NAT as well. Since I setup with my 3620 router, some URL is working fine and some is does not (like CNN.com or cisco.com). with PPPOE setup, I do not get the DNS ip address, so I manually set it in my DHCP config. But still does not working right. Anyone has same problem as mine ? Thanks for your response. Here is my configuration.
Router.FW.RO> en
Password:
Router.FW.RO#sh run
Building configuration...
Current configuration : 1676 bytes
version 12.3
hostname Router.FW.RO
boot-start-marker
boot-end-marker
logging buffered 210000 debugging
enable secret xxxxxxx
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip dhcp excluded-address 10.1.1.50 10.1.1.250
ip dhcp pool thieubui
network 10.1.1.0 255.255.255.0
default-router 10.1.1.50
dns-server 199.45.32.43 199.45.32.38
lease 7
ip inspect dns-timeout 3
ip audit po max-events 100
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0/0
ip address 10.1.1.50 255.255.255.0
ip nat inside
full-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Ethernet0/1
no ip address
ip tcp adjust-mss 1452
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp pap sent-username xxxx password xxxxx
ip nat inside source list 1 interface Dialer1 overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
^C
line con 0
line aux 0
line vty 0 4
password password
login
end
  • Other Network Infrastructure Subjects
VIP Purple
Re: PPPOE - DNS problem
I guess you have already checked the configuration of your hosts ?
Just to be sure try a couple of the DNS servers below, they are public ones; this just to exclude that your Verizon servers are overloaded:
199.166.28.10 (PS0.NS2.VRX.NET) - Apopka, Fl
199.166.29.3 (nl.public.rootfix.net) - Nederlands
199.166.31.3 (NS1.QUASAR.NET) - Orlando, FL, USA
195.117.6.25 (ZOLIBORZ.ELEKTRON.PL) - Poland
204.57.55.100 (NS1.JERKY.NET) - Boston, MA, USA
199.5.157.128 (ASLAN.OPEN-RSC.ORG) - Detroit, MI, USA
Georg
It also possible to add the dns entries manualy. If you use the command.
ip name-server
for instance
ip name-server 195.121.1.34
ip name-server 195.121.1.66
for each dns server you want to use, it should be possible to ping anything on the internet from the router console.
Remember that you need to adjust your MTU settings
with PPPOE MTU 1456 works well
332
