PPPoE L2TP
c.vergara
I ´m using a 7204 (12.2(15)T1) router for terminate PPPoE sessions, this is working fine. But i need to extend this ppp session through a L2TP tunnel from the same 7200 (LAC) until other router (LNS).
PPPoE Client-----7200(LAC)--------Router(LNS)
Is possible this solution ? If is affirmative which the configuration of the routers or any documentation about this ?
regards,
Carlos
9 Replies 9
zahmed
Carlos, I believe you need "L2TP Multihop" feature. Please check out the following:
http://www.cisco.com/warp/customer/471/l2tp_multihop2.html
You could seach CCO for more on L2TP Multihop. Let me know if you meant something else.
~Zulfi
tepatel
Absolutely..you can do that..Here is the link which discuss the same scenerio.
http://www.cisco.com/warp/public/794/pppoe_arch.html
Following config is tested and known to work for that scenerio,
On LAC 7200 terminating pvc 1/35
vpdn enable
vpdn search-order domain
vpdn-group 10
description to forward pppoe over l2tp to LNS
request-dialin
protocol l2tp
domain a@b.com
initiate-to ip 10.10.10.2 priority 1
no l2tp tunnel authentication
vpdn-group 4
accept-dialin
protocol pppoe
virtual-template 3
interface ATM4/0
no ip address
no atm ilmi-keepalive
pvc 1/35
protocol pppoe
interface Virtual-Template3
no ip address
ip mtu 1492
peer default ip address pool ADSL
ppp authentication pap
ip local pool ADSL x.x.x.x y.y.y.y
On LNS
vpdn-group 4
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname c7200
lcp renegotiation on-mismatch
interface Virtual-Template1
ip unnumbered FastEthernet0/1
ip local pool ADSL a.a.a.a y.y.y.y
thanks for your help, this configuration is working fine, the other router was a Shasta and was necessary add l2tp tunnel authentication in boths ends.
A last question, Is possible leave the l2tp tunnel static (always on) ?
Carlos
I don't think so that you can have always on l2tp tunnel without users in it. Any special reason why you need it?
The customer needs to know if the tunnel can is always on, because the Shasta has the option static on the tunnel configuration.
We have this hidden command "l2tp tunnel nosession-timeout " that goes under VPDN group after selecting "protocol l2tp". See if this does the job for you.
~Zulfi
Finally the command is "l2tp tunnel timeout no-session never" and must is on both end (LAC and LNS).
thanks for yous help.
Carlos
Needs to be on both ends since if the router is configured as a LAC, the default is 15 seconds. If the router is configured as an LNS, the default is 10 seconds.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tdr/drfisl2.htm#1141929
Thanks, Mak.
yes was neccesary apply this command in boths end. The implementation is working fine.
thanks,
Carlos
