PPPOE on Fast Ethernet interface
I'm attempting to configure PPPOE on FE interface on Cisco 2621XM to non-Cisco DSL CPE. I have the sampe config from Cisco's doc, but I am not sure about the dialer pool and dialer-group commands and what they reference. This router also has ISDN interfaces configured and I don't want to conflict with those dialer interfaces. Thank you
devans
Re: PPPOE on Fast Ethernet interface
Are you wanting the 2621 to authenicate the dsl cpe using pppoe..?
Hope this can give you a hint (I will assume that ISDN has pool1 and you're using an ADSL modem)
interface fa0
no ip address
pppoe enable
pppoe-client dial-pool-number 2
interface Dialer (2 or Whatever)
ip mtu 1492
ip address (whatever)
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 1
dialer-list 1 protocol ip permit //depends on your routes
Please keep me informed, alot of people had authentication problems,so make sure to supply the correct authentication type and the username/password at the dialer interface.
Good Luck
Yes, it appears I am having authentication problems or ? At this point I am unable to connect. Verified username/password with ISP, however debug ppp negotiation shows failure to negotiate with peer ? My config:
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Lxxxxxxx
logging buffered 40000 debugging
no logging console
enable secret xxxxxxxxxxxxx
enable password xxxxxxxxx
username xxxx
username xxxx
ip subnet-zero
no ip domain lookup
ip name-server 199.224.86.16
ip name-server 199.224.86.20
ip name-server 199.224.86.15
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group 5
request-dialin
protocol pppoe
isdn switch-type basic-ni
isdn voice-call-failure 0
voice call carrier capacity active
mta receive maximum-recipients 0
interface FastEthernet0/0
description Dushore LAN interface
ip address 10.0.0.1 255.255.0.0
ip nat inside
load-interval 30
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description Dushore Epix DSL interface
no ip address
load-interval 30
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 5
no cdp enable
interface BRI1/0
description ISDN BRI to Nicholson
no ip address
encapsulation ppp
dialer rotary-group 0
dialer-group 1
isdn spid1 9999999999
isdn spid2 8888888888
no cdp enable
ppp multilink
interface BRI1/1
description ISDN Connection to Tunkhannock
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn spid1 88888888
isdn spid2 88888888
no cdp enable
ppp multilink
interface BRI1/2
description ISDN BRI to Lacyville
no ip address
encapsulation ppp
dialer rotary-group 2
dialer-group 1
isdn spid1 777777777
isdn spid2 77777777
no cdp enable
ppp multilink
interface BRI1/3
no ip address
shutdown
interface Dialer0
description ISDN Connection to Nicholson
ip address 192.168.1.1 255.255.255.252
encapsulation ppp
dialer in-band
dialer idle-timeout 999999
dialer map ip 192.168.1.2 name LECHSNICH802 broadcast 639xxxx
dialer load-threshold 1 either
dialer-group 1
no cdp enable
ppp authentication chap
interface Dialer1
ip address 192.168.1.5 255.255.255.252
encapsulation ppp
dialer in-band
dialer map ip 192.168.1.6 name LECHSTUNK802 broadcast 639xxxx
dialer-group 1
no cdp enable
interface Dialer2
description ISDN Connection to Lacyville
ip address 192.168.1.9 255.255.255.252
encapsulation ppp
dialer in-band
dialer map ip 192.168.1.10 name LECHSLACY804 broadcast 639xxxx
dialer-group 1
no cdp enable
interface Dialer5
description Dialer Interface for DSL
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 5
dialer idle-timeout 0
dialer persistent
dialer-group 5
no cdp enable
ppp authentication pap
ppp pap sent-username abcde@epix.net password xxxxxxxxxxxx
ip nat inside source list 1 interface Dialer5 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer5
ip route 10.1.0.0 255.255.0.0 192.168.1.2
ip route 10.2.0.0 255.255.0.0 192.168.1.6
ip route 10.3.0.0 255.255.0.0 192.168.1.10
no ip http server
access-list 1 permit 10.0.0.0 0.0.255.255
dialer-list 5 protocol ip permit
call rsvp-sync
mgcp profile default
dial-peer cor custom
banner motd ^Cx^C
line con 0
exec-timeout 5 0
password 7 125D003B1708220D293B252634
login
line aux 0
line vty 0 4
exec-timeout 5 0
password xxxx
login
transport input telnet
line vty 5 15
exec-timeout 5 0
password 7 xxxxxx
login
end
Now try to disable the authentcation, "no ppp authentication pap". Yes
leave it with no authentication type.
Good Luck
If it worked with you (as I guess), then re-enable the authentication using this command:
ppp authentication pap callin
Note that without the "callin " your router will try to authenticate the other side, so your router must have a username/password entries for the peer. With "Callin", your router does not require the called router to authenticate.
Hope I helped
Jawad
Nope, did not work. Looking through some of the debug outputs, the virtual-access interface and the dialer interface come up, it appears to be attempting to authenticate, and then the interfaces go down. It may not be able to authenticate because it doesn't connect, I don't know. ?
I don't see anything wrong in your config, but I don't see the need for rotary groups since you are not grouping multiple connections, I also think that some dialer pool commands are needed, however this, has nothing to do with the ADSL connection and the dialer 5 interface or the fast ethernet interface.
I think you should check the connection itself on a windows machine for example. Can you dump the debug output, it would help alot. Please use the "debug vpdn pppoe-error" and the "debug ppp authentication".
Jawad
Jawad,
I solved the problem by using the command "ppp chap refuse". Apparently the router or the ISP was trying to authenticate with chap first, when I needed pap only. Thanks for all your help ?
PS, as for the rotary groups, I'm unfamilair with ISDN and this is how I got things to work.
D. Evans
466
