PRI ans SLIP connection
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
im trying to implement RAS server so a remote unix server can dial in using SLIP. The user dials in OK but having issues passing L3 traffic. Sh ip route shows route for the user. Im copying the config . Any suggestions on the config or troubleshooting would be great
Current configuration : 1875 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname xxx
boot system flash c3660-is-mz.122-16a.bin
logging queue-limit 100
enable -- moderator edit-- password **********
username test password 0 test
ip subnet-zero
no ip domain-lookup
isdn switch-type primary-net5
isdn voice-call-failure 0
modemcap entry mica_rog:MSC=&F&D2S0=0S34=18000S40=10S10=50debugthismodemS71=4s53=0
call rsvp-sync
fax interface-type fax-mail
mta receive maximum-recipients 0
controller E1 1/0
pri-group timeslots 1-31
controller E1 2/0
interface Loopback1
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/0
ip address 10.10.11.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
ip unnumbered Loopback1
encapsulation ppp
dialer-group 1
isdn incoming-voice modem
no fair-queue
interface Serial2/0:15
no ip address
no fair-queue
interface Group-Async1
encapsulation slip
dialer in-band
dialer idle-timeout 1200
dialer-group 1
async default routing
async dynamic address
async mode interactive
no peer default ip address
group-range 97 158
ip classless
ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
dial-peer cor custom
line con 0
login
line 97 126
flush-at-activation
login local
modem InOut
modem autoconfigure type mica_rog
transport input all
autoselect during-login
line 129 158
flush-at-activation
login local
modem InOut
transport input all
line aux 0
login
line vty 0 4
login
end
Bronze
Re: PRI ans SLIP connection
Try "no ip route-cache" under group async. Also see if removing "async dynamic address" has any effect.
~Zulfi
hi Zulfi
Thanks for yr reply. I managed to get it working by removing dialer in-band from the Async interface. SLIP wasn't happy with it and I was getting encapsulation failed in the debugs
Ati
98
