pri b-channel problem
We have a ISDN pri line in Seul connected to a router 2620 (MPC860) on which runs the ios c2600-js-mz.122-7b.bin.
Here is a part of the router configuration :
username xxxxxx password 7 xxxxxxxxxxx
controller E1 1/0
framing NO-CRC4
linecode ami
pri-group timeslots 1-31
interface Serial1/0:15
description PRI Numero xxxxxxxxxxxx
bandwidth 2048
no ip address
encapsulation ppp
load-interval 30
dialer pool-member 1
isdn switch-type primary-net5
no fair-queue
ppp link reorders
ppp multilink
ppp timeout idle 300 either
interface Dialer0
ip address xxxxxxxx xxxxxxxx
no ip unreachables
encapsulation ppp
dialer pool 1
dialer idle-timeout 300 either
dialer string xxxxxxxxxxxxx
dialer-group 1
no cdp enable
ppp authentication chap
ppp chap hostname xxxxxxxx
ppp multilink
multilink min-links 30
Here are results of the command debug ISDN q921:
Nov. 26 10:46:59 UTC: ISDN Se1/0:15: TX - > SABMEp c/r=0 sapi=0 tei=0
Nov. 26 10:47:00 UTC: ISDN Se1/0:15: TX - > SABMEp c/r=0 sapi=0 tei=0
Nov. 26 10:47:01 UTC: ISDN Se1/0:15: TX - > SABMEp c/r=0 sapi=0 tei=0
Nov. 26 10:47:02 UTC: ISDN Se1/0:15: Vent: received NL_REL_IND
and those of the command debug ISDN event:
Nov. 26 10:48:05 UTC: ISDN Serial1/0:15: isdn_is_bchannel_available: No Free B-channels.
Nov. 26 10:48:07 UTC: ISDN Serial1/0:15: isdn_is_bchannel_available: No Free B-channels.
Nov. 26 10:48:09 UTC: ISDN Serial1/0:15: isdn_is_bchannel_available: No Free B-channels.
Nov. 26 10:48:11 UTC: ISDN Serial1/0:15: isdn_is_bchannel_available: No Free B-channels.
Nov. 26 10:48:13 UTC: ISDN Serial1/0:15: isdn_is_bchannel_available: No Free B-channels.
sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
I_Queue_Len 0, UI_Queue_Len 0
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x7FFF7FFF
Number of L2 Discards = 0, L2 Session ID = 10
Total Allocated ISDN CCBs = 0
I would like to know what could be the cause of the unavailability of the b-channel and also why the state of layer 2 is not in MULTIPLE_FRAME_ESTABLISHED
1 REPLY
Re: pri b-channel problem
Since the SABMEp's from the router is not replied by telco to sync-up layer 2, it looks like a probelm in the telco switch..So you need to talk to telco company to get it fixed..However you can try to follow the docs below to see the E1-controller hardware is good or not by doing a hardware loopbak test
http://www.cisco.com/warp/public/116/e1_hard_loopback.html
Now here is the good doc for troubleshooting for E1 lines
http://www.cisco.com/warp/public/116/E1_pri.html
130
