Community Member
PRI Channel Configurations - Help Needed !!!
Anyone please help to clarify my queries below;
(1) I were to use a channelized PRI line with 30 channels on my 3620 router, how do I configure the number of PRI channels that should be occupied by each remote dial in office ?
(2) For the 30 PRI channels, all remote dial in offices will call the same phone number or call different number respectively ?
(3) If I were to the 16 PRI channels for incoming calls and the rest of channels all will be use by the router to call out to another HQ office, how do I configure the router then ?
(4) Is there any similar configuration samples for such scenerio ?
Please help out .
Thank you.
Community Member
Re: PRI Channel Configurations - Help Needed !!!
Hello.
Answering your questions:
1- You can work with dialer profiles , with each dialer profile you can assign a dialer max-call n (where n is the B channels available for this user) , also you can define a user properties:
username **** user-maxlink n .
2- All remote users call to the same number until the PRI is full.
3- If you work with dialer profiles you can define 2 dialer pool-member:
dialer pool-member 1 max-link 16 ( 16 channels assigned)
dialer pool-member 2 max-link 14
Then each dialer profiles for dial in users you assign dialer pool 1 and for dial out users you assign dialer pool 2 .
4 - You'll find samples in PRI dialer profiles configuration samples.
Community Member
94
