PRI Controller Resets and Calls re-establishing
I am experiencing controller resets
%CONTROLLER-5-UPDOWN: Controller E1 1/0, changed state to down
It recovers almost immediately (not sure if it is a carrier problem yet). The disturbing thing is that the dialer at the distant end has to be manually reset for the link to recover.
The calls at the end that has the reset are dropped and then attempt to re-establish.
The incoming calls at the far end stay up hence giving busy tone when the calls are re-attempted.
--- Controller Reset end ---
controller E1 1/0
pri-group timeslots 1-31
interface Serial1/0:15
no ip address
encapsulation ppp
ip route-cache flow
dialer pool-member 1
no snmp trap link-status
isdn switch-type primary-net5
ppp authentication chap callin
interface Dialer1
description --- Link to Cairns ---
ip address 10.34.36.2 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 30
dialer pool 1
dialer remote-name cairns_coen
dialer idle-timeout 300 either
dialer fast-idle 5
dialer enable-timeout 5
dialer string 0740402600
dialer caller 740402600 callback
dialer load-threshold 125 either
dialer max-call 6
dialer-group 2
ppp chap hostname coen_cairns
ppp multilink
ppp multilink fragment-delay 10
ppp multilink links maximum 6
ppp multilink links minimum 1
ODN01COE1NR01#show controllers e1
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (486 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
1 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 6 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 6 Severely Err Secs, 0 Unavail Secs
--- Receiving side that has to have a dialer reset --
controller E1 1/0
no ip address
encapsulation ppp
ip route-cache flow
interface Dialer1
description --- Link to Coen ---
ip address 10.34.36.1 255.255.255.252
encapsulation ppp
ip route-cache flow
no ip mroute-cache
load-interval 30
dialer pool 1
dialer remote-name coen_cairns
dialer fast-idle 5
dialer enable-timeout 30
dialer string 0740835444
dialer caller 740835444
dialer hold-queue 20
dialer max-call 6
dialer-group 2
ppp chap hostname cairns_coen
ppp multilink
ppp multilink interleave
1 REPLY
Bronze
Re: PRI Controller Resets and Calls re-establishing
See if increasing the 'dialer enable-timeout' value of 5 on the calling side to some higher value helps.
80
