PRI Problem on Cisco 3640 router (TEI_ASSIGNED)
I have a Cisco 3640 router with 4-port Channelized E1 inserted. One of these E1 ports is used as an ISDN PRI connection to Telco for ISDN backup purposes. Branch offices, who are able to dial using ISDN BRI interfaces, try to connect to E1 PRI port.
However, something goes wrong and I was unable to dial out (or connect to) anywhere from my router. Besides, nowhere is able to dial in. The following configuration does not work on the interface:
isdn switch-type primary-net5
controller E1 3/1
framing NO-CRC4
pri-group timeslots 1-31
description Pri to Bri
interface Serial3/1:15
bandwidth 64
no ip address
encapsulation ppp
dialer pool-member 101
dialer pool-member 25
ppp authentication chap
ppp multilink
interface Dialer25
description test
bandwidth 60
ip unnumbered Loopback0
encapsulation ppp
dialer pool 25
dialer load-threshold 200 either
dialer-group 1
no snmp trap link-status
pulse-time 0
ppp multilink
dialer-list 1 protocol ip permit
Router#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial3/1:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
TEI = 60, Ces = 1, SAPI = 30, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Total Allocated ISDN CCBs = 0
1- Is it possible to see two distinc TEI under Layer 2 status item? Shouldn't it be single TEI?
2- Although I have tried various commands under 'Serial 3/1:15', nothing changed? What do you suggest next?
Thanks for all..
Onur
1 ACCEPTED SOLUTION
Bronze
Re: PRI Problem on Cisco 3640 router (TEI_ASSIGNED)
Hi Onur,
This sounds like CSCdt42505 (Two different Layer 2 status are reported by sh isdn stat) which was dup'ed to CSCuk23244. The release note of CSCuk23244
says as follows :
Configuring a PRI controller for ISDN with the pri-group command may cause ISDN layer 2 failure to establish. Saving the ISDN configuration and reloading the router will resolve the problem, or performing a shut followed by "no shut" on the PRI controller may also resolve the problem.
So I believe the crash kind of did the similar task to your router and brought the layer 2 up. I think your permenant fix is to upgrade the IOS according to CSCuk23244 or the problem will come up again at some other time.
~Zulfi
No..TEI should be 0 for T1/E1 PRI unless some other services are subscribed.
Looks to me that the E1 line is not in sync with switch on layer 2. So you need to make sure that "sh controller E1" reports clean stats. Here are some urls which will help you to troubleshoot layer 2 issues
http://www.cisco.com/warp/public/116/E1_pri.html
It also has some more useful links under "related docs" on the bottom of that page.
Silver
"debug isdn q921" will be useful...I would think that PRI tei would be zero.
http://www.cisco.com/warp/public/116/T1_pri.html
Thanks, Mak.
At the time I have entered "debug isdn q921", the following messages were received:
Apr 29 09:20:35 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:36 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:37 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:38 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:39 MEST200: ISDN Se3/1:15: Event: received NL_REL_IND
While playing with the confuguration of Serial3/1:15, and trying to enter 'dial string' for Dialer 25, suddenly router crashed and reloaded itself immediately. The surprising thing is that ISDN status turned into "MULTIPLE_FRAME_ESTABLISHED"!! All 'dial in' and 'dial out' configurations work now.
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
IOS is 'c3640-is-mz.121-5.T9.bin'. I think there happened something related with an IOS bug. Now on, I will control the proper operation of ISDN PRI link.
Thanks a lot,
Onur
Bronze
Hi Onur,
says as follows :
~Zulfi
355
