PRI Problem on Cisco 3640 router (TEI_ASSIGNED)
I have a Cisco 3640 router with 4-port Channelized E1 inserted. One of these E1
ports is used as an ISDN PRI connection to Telco for ISDN backup purposes. Branch
offices, who are able to dial using ISDN BRI interfaces, try to connect to E1 PRI
port.
However, something goes wrong and I was unable to dial out (or connect to) anywhere
from my router. Besides, nowhere is able to dial in. The following configuration
does not work on the interface:
isdn switch-type primary-net5
controller E1 3/1
framing NO-CRC4
pri-group timeslots 1-31
description Pri to Bri
interface Serial3/1:15
bandwidth 64
no ip address
encapsulation ppp
dialer pool-member 101
dialer pool-member 25
ppp authentication chap
ppp multilink
interface Dialer25
description test
bandwidth 60
ip unnumbered Loopback0
encapsulation ppp
dialer pool 25
dialer load-threshold 200 either
dialer-group 1
no snmp trap link-status
pulse-time 0
ppp multilink
dialer-list 1 protocol ip permit
Router#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial3/1:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
TEI = 60, Ces = 1, SAPI = 30, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Total Allocated ISDN CCBs = 0
1- Is it possible to see two distinc TEI under Layer 2 status item? Shouldn't it be
single TEI?
2- Although I have tried various commands under 'Serial 3/1:15', nothing changed?
What do you suggest next?
Thanks for aid..
Onur
Re: PRI Problem on Cisco 3640 router (TEI_ASSIGNED)
I would recommend turning on 'debug isdn q921' and 'debug isdn q931' then putting your output in Cisco's 'output interpreter' tool.
Make sure you have the correct ISDN Switchtype.
Please check your controller e1 before troubleshooting the ISDN partion.
Make sure it is up and running clean with no error first.
Then you can run debug isdn q921 and use "sh interface s3/1:15"
and look at the counters for input/output packets count.
Here is an url for troubleshooting E1:
http://www.cisco.com/en/US/tech/tk713/tk584/technologies_tech_note09186a00800f9e3a.shtml
You can also take a look at this url for T1:
http://www.cisco.com/en/US/tech/tk713/tk584/technologies_tech_note09186a00801509d7.shtml
Just apply the same logics to the E1 controller.
Chinh
At the time I have entered "debug isdn q921", the following messages were received:
Apr 29 09:20:35 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:36 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:37 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:38 MEST200: ISDN Se3/1:15: TX -> SABMEp c/r = 0 sapi = 0 tei = 0
Apr 29 09:20:39 MEST200: ISDN Se3/1:15: Event: received NL_REL_IND
While playing with the confuguration of Serial3/1:15, and trying to enter 'dial string' for Dialer 25, suddenly router crashed and reloaded itself immediately. The surprising thing is that ISDN status turned into "MULTIPLE_FRAME_ESTABLISHED"!! All 'dial in' and 'dial out' configurations work now.
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
IOS is 'c3640-is-mz.121-5.T9.bin'. I think there happened something related with an IOS bug. Now on, I will control the proper operation of ISDN PRI link.
Thanks a lot,
Onur
239
