Community Member
Priority-group on ATM interface
I am having a problem with configuring an atm point-to-point interface with a priority-group. I'm able to enter the command w/o any errors, but when I go back to look at the config, it doesn't appear to be configured.
I also have a seperate group of ATM interfaces on this router which are group together for IMA, these have been configured with the same priority-group I'm needing to use.
ATM 1/4 and 1/5 are the interfaces I'm having problems with, ATM 1/0 and 1/1 are working.
interface ATM1/4
mtu 1544
no ip address
ip load-sharing per-packet
atm vc-per-vp 256
no atm ilmi-keepalive
no scrambling-payload
interface ATM1/4.32 point-to-point
description ATM T-1 to Sault Ste Marie
mtu 1544
ip address 204.105.199.53 255.255.255.252
pvc 0/32
protocol ip 204.105.199.54 broadcast
vbr-nrt 1500 750 3600
encapsulation aal5snap
interface ATM1/5
mtu 1544
no ip address
atm vc-per-vp 256
interface ATM1/5.33 point-to-point
mtu 1544
ip address 204.105.199.65 255.255.255.252
pvc 0/33
protocol ip 204.105.199.66 broadcast
interface ATM1/0
description ATM T-1 to Phnx
no ip address
no ip mroute-cache
atm vc-per-vp 256
ima-group 0
priority-group 1
interface ATM1/1
no ip address
no ip mroute-cache
atm vc-per-vp 256
ima-group 0
priority-group 1
interface ATM1/IMA0.43 point-to-point
description 3MB IMA to phx-gmr-rtr1 - includes a1/0 and a1/1
ip address 204.105.199.37 255.255.255.252
pvc 5/43
protocol ip 204.105.199.38 broadcast
vbr-nrt 3000 1500 7200
access-list 177 permit udp any any range 30000 39999
priority-list 1 protocol ip high list 177
Any ideas?
Re: Priority-group on ATM interface
priority-queueing, custom-queueing and native fair-queueing are not supported on ATM interfaces. You have to configure Class Based Weighted Fair Queueing or Low Latency Queueing to achieve similar things.
More information about this at the following URL:
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:ATM:IP_ATM&viewall=true
Community Member
I'll check it out. Thanks
110
