Webcast-Catalyst9k
Priority Queuing problem
The following is my priority queueing configuration
access-list 1 permit 1.20.0.2
access-list 1000 permit FFFFFFFF 4
priority-list 1 protocol ip high tcp telnet
priority-list 1 protocol ip low
snmp-server community public RO
is it correct? or the "priority-list 1 protocal ip low" will overwrite the everything and drop telnet?
Raymond
1 REPLY
Silver
Re: Priority Queuing problem
With priority queuing, the scheduler will service High queue packets first. Once high queue is empty only then attention will be given to low priority queues.
In your case, you wont lose your telnet connections. Since you have multiple rules for a single protocol (IP), just make sure your order appears the way you have pasted above, high statement should appear first in config.
Thanks.
111
